diff and tran case fluid - JeepForum.com
post #1 of 4 Old 02-26-2002, 11:06 AM Thread Starter
dpoliver
Question diff and tran case fluid
how often should i be changing these and with what...?
and how do you go about it?
86 cj7 4.2l i6,torqueflite 904 at,
GM hei ignition, weber,
31 in a/t tires, so far...
dpoliver is offline
post #2 of 4 Old 02-26-2002, 11:28 AM
CJeep
Alpha dog
CJeep's Avatar
1982 CJ8
Cool
I'd go with about every 60K miles or so. All diffs should use gear oil, I think it's the 85w90 stuff - but check. If you have a Dana 300, it also uses the same.
'82 Scrambler - NV4500/4.5" lift/33" Toyo MTs/4.0/twin stick, and my windshield washers work! Full 1/2 cab Cage
2004 Grand Limited 4.7 HO - OH Boy!
2010 Grand Laredo 5.7 Hemi - SICK - back for a second time!
"Both my Doberman and my Jeep can accurately be described as 'black and rust.'"
CJeep is offline
post #3 of 4 Old 02-26-2002, 12:03 PM Thread Starter
dpoliver
Question
is there a drain plug or do you need to remove the cover...how do you check the level?
dpoliver is offline
post #4 of 4 Old 02-26-2002, 04:03 PM
1911shtr
Post
I change mine once a year. I try to stay out of the water but it is soooooo hard. If it is an manual like mine it will have drain plugs under the skid plates. The fill plugs are on the sides of the cases. You will fill them untill the oil starts running out the holes. Their full. Go buy a chiltons. they really come in handy.
1911shtr is offline
T-case and diff changes?? Phiber0p Jeep CJ Forum 9 04-24-2008 05:24 PM
changing diff fluid long71 Jeep CJ Forum 6 10-11-2006 05:13 PM
Diff Fluid 1979CJ7 Jeep CJ Forum 13 08-01-2006 01:43 PM
Questions on how-to change diff fluid, and others Hale Jeep CJ Forum 2 03-23-2004 02:25 PM
Diff case question hollywood Jeep CJ Forum 1 06-17-2003 10:53 PM
