Diferential And Transfer Case Oil ? - JeepForum.com
post #1 of 11 Old 07-06-2013, 02:25 PM Thread Starter
Oily
Rear Dana 20, Front Dana 30, D300 transfer case.
All 90 weight, correct ?
Oily is offline
post #2 of 11 Old 07-06-2013, 07:22 PM
CSP
Doesn't have to be 90wt.
You could use 75w-90, 75w-120, 80w-90, etc.
What's important is that the axles get oil rated as GL-5. The transfer case can use GL4 or GL5.
CSP is offline
post #3 of 11 Old 07-06-2013, 08:34 PM
Tweeter00801
1978 CJ7
I've heard the argument for GL4 in the transmission, but why is it important for the diff to have GL5? I'm curious since I too am about to lube up the diff.
Can I use GL4 on the Diff?
Tweeter00801 is offline
post #4 of 11 Old 07-06-2013, 11:36 PM
brownbagg
1930 MK Compass
its 90 weight
brownbagg is offline
post #5 of 11 Old 07-06-2013, 11:56 PM
CSP
GL5 is rated for hypoid gear sets. Differential gears are hypoid gears (the shape of the cut) and GL4 isn't rated for the pressures that hypoid gears see.
CSP is offline
post #6 of 11 Old 07-07-2013, 08:02 AM
shadoow
my setup is dana 20, dana 30 and dana 300, and T177. I use GL-5 in all the danas and GL4 in the T177
shadoow is offline
post #7 of 11 Old 07-07-2013, 11:57 AM Thread Starter
Oily
Hmm. Next question(s). How can I tell if it is GL-4 or GL-5 ? What is the difference ?
The thing is, I drill oil wells for a living. We use 10wt (hydraulic fluid), 30wt non detergent chain oil, 10w40/50w motor oil, an 90w gear oils. We use a lot and keep a lot on hand in bulk. They allow us to take some for personal use (even diesel fuel, small quantities for off road use). I don't remember the last time I bought oil.
I am not with the same company from which I refilled an old 5qt oil jug, so I can not refer back to the original label.
Thanks.
Oily is offline
post #8 of 11 Old 07-07-2013, 09:13 PM
CSP
The oil container will be marked with an API service rating. This will be GL4 or GL5.
CSP is offline
post #9 of 11 Old 07-08-2013, 06:29 AM
roboto65
1976 CJ5
I have heard of guys that run straight 50 wt in there transmissions.
They say money can't buy happiness but it can buy Jeep parts...and Jeep parts make me really Happy.
roboto65 is offline
post #10 of 11 Old 07-08-2013, 08:57 AM
CSP
That straight 50 wt is 50wt motor oil. Motor oil viscosity and gear oil viscosity is measured differently and 50wt motor oil is about the same as 80wt gear oil.
CSP is offline
post #11 of 11 Old 07-08-2013, 09:05 AM
roboto65
1976 CJ5
Sorry yeah meant to say 50wt Motor oil I tryed finding some but did not look to hard yet LOL
roboto65 is offline
