Did I say I hate Torx bolts. Want to replace them all - JeepForum.com
post #1 of 34 Old 04-26-2013, 09:36 AM Thread Starter
cobrao4
I can't tell you how many bolts I had to weld a nut to in order to get them off. I think all but one of the roll cage bolts stripped out. Anyway what is the general concensus among you guys.... Replace them with the original torx bolts or buy a good quality grade-8 hex bolt where possible.
Is there a thread that shows an all inclusive list on bolt sizes?
cobrao4 is offline
post #2 of 34 Old 04-26-2013, 09:40 AM
CrawlingForward
I'm not a CJ, but whenever I pull out a Torx on the YJ, a non-torx grade-8 hex goes back in, unless the Torx came out *really* easily.
It's just not worth the aggravation if you ever need to go back it. One sneeze or slip or bad angle while wrenching on a torx and it's half stripped out.
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline
post #3 of 34 Old 04-26-2013, 10:45 AM
only in a jeep cj
I use heat (MAP gas) on the bottom or nut side and zip them right out with an impact gun. Of the thousands Ive removed over the last 22 years, Ive only had to drill the head off about 10 of them. I for one like them and generally don't have a problem with them.
3 most common mistakes I see with them
1. Not cleaning the dirt out of the center and the bit is only partly inserted...yes this can strip it.
2. using the wrong size...the dash bolts are a T27...not a T25 that most try to use.
3.not using heat or trying to just break free the torx...example...the windshield/upper door hinges at the tub cowl needs to have the torx held while the nut inside is the one spun or broke free with a wrench.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is online now
post #4 of 34 Old 04-26-2013, 11:19 AM
Renegade82
1982 CJ7
I usually replace them in most cases. I've noticed lately that places are calling them "star" bolts or sockets instead of Torx. Is it just the ignorance of a new generation or is it a copyright thing?
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #5 of 34 Old 04-26-2013, 11:33 AM
titomars
1981 CJ7
I personally have not had any real trouble from Torx head fasteners specifically. Well no more trouble than say Allen head fasteners. Like Allen head fasteners they hate impact tools. It just beats them up. I actually like them. Means my pieces and parts stand a better chance of staying on the CJ and not growing legs during the night (theft). I also like the look of them. but the key to success with them is to make sure the socket of the fastener is clean and having the tool squarely engaged into the fastener.
1981 Jeep CJ7 4.0 HO, AX-15, D300, D30, D44, SOA
1977 Chevrolet C/10 step side 454 TH400 3.73 posi
titomars is offline
post #6 of 34 Old 04-26-2013, 12:30 PM
wellmax
on those that I can not get to the nut with heat, each old jeep should come with it's own acetylene torch kit.
time and patience is a plus,
I have had some success with the following:
I heat the head of the torx bolt up to cherry red, then let it cool, do this 2/3 times. each time the heat travels down the bolt and expand inside the nut. normally this will break the bond between bolt and nut.
then as said before use the right size bit, I use my hand held im-pack wrench on the bolt head.
with each blow it upsets or shocks the bolt as it try's to turn the bolt at the same time.
if I can ever get the bolt to move, that means the rust bond is broken
then I try to get it out, if not then I coat it with a mixture of (acetone and automatic trans fluid, one of the best penetrating fluids out there). however very flammable!!!!!!!!!!!
if all this does not work then you have no option, but to drill it out, at least having the torx hole is a good place to start as it will hold you drill bit centered.
wellmax is offline
post #7 of 34 Old 04-26-2013, 04:16 PM
Jim1611
Jim1611's Avatar
Any fastener that has an angle under the head like torx of flat head cap screws should have anit-sieze on the threads and under the head. Keep that in mind when you put the new ones back and if you need to take the out again you'll have a much easier time of doing it. For that matter you need to use anit-sieze on anything with threads on the outiside of the rig unless it's the brakes or spindles.
Jim1611 is offline
post #8 of 34 Old 04-26-2013, 04:26 PM
cj7ole
I replaced most of mine with socket head (Allen) stainless steel, if it looked like a high stress bolt, I went up one size. I like the looks of socket head vs hex. Stay away from button head, they look trick but the small socket strips way too easy. Have to remove a bolt 15 years from now? No problem. We did a full tear down/repaint 15 years after replacing the fasteners, and everything came apart easily. There is a place for grade 5 and 8: roll bars, seat belts, bumpers, tow hooks, winches, spring hangers, but windhield hinges (these are real problems) and other body mounts work fine with stainless.
'84 CJ7, '07 5.3 LMG Chevy, D300, 4L60e, 33's, 4.10, rear Detroit Locker, FG Tub, HOK Tangelo Pearl
Build: http://www.jeepforum.com/forum/f22/ole-jays-cj7-5-3-chevy-swap-1287392/
cj7ole is offline
post #9 of 34 Old 04-26-2013, 06:22 PM
82JeepCJ7
1982 CJ7
I took most of them out, put them in a can, then took them to the lake with my sling shot. Fun seeing how far you can get them.
Almost everything gets stainless now.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #10 of 34 Old 04-26-2013, 06:29 PM
keith460
Jeep. There's Only One
keith460's Avatar
Personally, I like the Torx bolts as they seem to be an anti-theft fastener for the most part and have installed several factory items under the dash like cigarette lighter, radio bracket with tamper-proof Torx bolts that are available. I have retained the factory Torx bolts for the roll bar, dash and anywhere else that AMC/Jeep used them because they are unique to the CJ. I even went as far as sandblasting them and then sent them out to be Nickel plated, but I always use a copper based anti-seize compound before installing them or any other piece of hardware on the Jeep. They always come out no matter what exposure they have had over time.
Anti-seize compound is the "key" to removing fasteners in the future and has served me well for the last 25 years or so.
1984 CJ-7 Renegade
keith460 is offline
post #11 of 34 Old 04-26-2013, 07:11 PM
RoostrRiz
I'm right there with you. Started swapping my roll bar today. So far four of the Torx came out all the rest have striped or are on the way there it seems. Already got some out by the weld a nut to it method but ill probably replace them with something else.
RoostrRiz is offline
post #12 of 34 Old 04-26-2013, 08:54 PM
jumbojeepman
1976 CJ7
What are you a glutton for misery? The only bolt that strips out more than a Torx is an Allen head. I'd like to take Mr. Allen behind a woodshed and give him a whooping for all the misery he's caused me over the years.
jumbojeepman is offline
post #13 of 34 Old 04-26-2013, 11:33 PM
cj7ole
The ones that cause me pain are the old-fashioned slotted screw heads. Strip 'em almost every time. The button heads and countersunk's that 82jeepcj7 used are a problem because the wrench is too small for the thread size and the hole is too shallow, that is why I use the capscrew style like you see in the hood hinge bolts in my pic. 5/16" threaded capscrews use a hefty 1/4" Allen wrench. You will break the bolt before you strip out the hole as long as you insert the wrench all the way to the bottom. I agree that regular hex heads will allow you to put the most torque on the bolt. Non-stainless alloy steel Allen (socket) head capscrews are usually about 25-40% stronger than grade 8. Allowable tightening torque for a flat head or button head is about half that of a full socket head, that is why they strip so easily.
cj7ole is offline
post #14 of 34 Old 04-27-2013, 12:06 AM
82JeepCJ7
1982 CJ7
The counter sunk bolts I used were on the windshield frame, so they only come out about once every 20 years. They were put in with Anti-seize, as were all of my bolts. The socket in these are pretty deep, about twice the depth as some I have seen.
post #15 of 34 Old 04-27-2013, 03:15 AM
John Strenk
John Strenk's Avatar
1976 CJ5
I replace all of my bolts with Stainless also. Years of salt haven't touched them you.
I actually like the torx design. you can put a lot more force on it than an allen.
Funny thing about those in our CJ was I read that there was thread locker on the screws and you need to heat the bolt up to remove them. which is kinda like what welding a nut on it does.
John Strenk is offline
