Did heater core, and blower motor upgrade, no fan now. - JeepForum.com
post #1 of 14 Old 02-07-2009, 08:12 PM Thread Starter
Blthomas
Blthomas's Avatar
1979 CJ7
I hate to make 5 threads about all my issues, but figured they are separate items, so I'll go with it.
Swapped the old heater core two weeks back, and got the blower motor upgraded.
My other fan worked, but since I was there, I did the swap.
Now, I have no fan. The fuse is good under the dash, it's only got the one wire for pete's sake, what could be the deal?
Now that I have it assembled, can I test it with straight 12v from the battery?
I'm having issues with my lights right now in another thread, be nice if I could nail this down too.
Thanks very much for all the help.
79' CJ7 - 4" lift, 33's
81' CJ8 bone stock
80' Chief "S" 6" lift, 33's
Blthomas is offline
post #2 of 14 Old 02-07-2009, 08:50 PM
Mike78cj7
1978 CJ7
If your fan worked before you upgraded your new fan isn't grounded. But you should still check the wire feeding the fan before you go tearing it apart.
If you don't have a test light or meter try like you said and run a wire directly to the fan to see if that works. If not then it's a bad ground. If it does work it's the switch.
Mike78cj7 is offline
post #3 of 14 Old 02-08-2009, 12:13 AM
kickingprop
yeah the fan uses the firewall as a ground....so if it doesnt have good contact for a ground its going to be worthless. I'd go check the ground by touching a jump wire from the portion sticking out of the firewall in the engine bay to a solid ground and see if it works.
1985 CJ7 Project
Phase One : 5.3L Vortec/4L60E, Moser axles for AMC20, Twin Stick'd Dana300 - Completed
Phase Two: Bedliner, Rollcage, Seats, BESRK Rear Bumper w/ tire swing, Soft Top, and a few other goodies - Mostly Complete
Phase Three: Waggy 44 front, Scout D44 Rear, 4.56's, ARB's (F/R) SOA with YJ Springs, 35x12.50x15 BFG MT - Not Even Close to beginning
Also a mostly rust-free 1970 Scout 800A That I'll get to start working on someday...
Chrome won't get you home...BUT Rattle Can Black may just get you back"
kickingprop is offline
post #4 of 14 Old 02-08-2009, 04:41 PM Thread Starter
Blthomas
Blthomas's Avatar
1979 CJ7
Hmmmmm. I had to cut the fire wall like most guys that did mod, problem is my hole was enormous. After I cut it, I was like damn! I guess I miss marked it when I drew the circle.
So I thought I would use some cork gasket and some RTV and seal it up. My rig is more function than looks.
Think all my RTV has somehow killed the ground?
I guess I'll tear it apart tomorrow if I can get my wiring fixed on my lights.
Thanks for the thoughts.
81' CJ8 bone stock
Blthomas is offline
post #5 of 14 Old 02-08-2009, 04:50 PM
BioTex
1979 CJ7
Might be easier to add a ground wire/strap.
Use a self tapping screw on the outer housing after you sand off a clean spot. Put some solid #10 wire under it, and then to ground elsewhere. If it works, I'd go with it.
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #6 of 14 Old 02-08-2009, 04:51 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Got a lot of those self drilling , self tapping screws? I got a box of them myself.
John Strenk is offline
post #7 of 14 Old 02-09-2009, 06:16 AM
Oily
NO. It does not ground there. In fact, it does not ground directly to the firewall. The heater motor bolts to the blower motor/heater core housing which bolts to the firewall (those four studs going into the engine bay). You should be able to put a ground wire on any of those bolts to keep from making another screw hole.
Oily is offline
post #8 of 14 Old 02-09-2009, 07:34 AM Thread Starter
Blthomas
Blthomas's Avatar
1979 CJ7
Thanks, I'll try that and see how it goes. I need to test the positive too, although like stated above it worked fine a couple weeks back.
81' CJ8 bone stock
Blthomas is offline
post #9 of 14 Old 02-09-2009, 10:31 AM
John Strenk
1976 CJ5
You know, I think I'm getting his lights issues mixed up with his heating issues.
post #10 of 14 Old 02-10-2009, 11:09 AM Thread Starter
Blthomas
Blthomas's Avatar
1979 CJ7
Might be. I picked up some self tapping screws, and new studs for the rear lights last night.
I'm going to try and knock this stuff out the next day or two.
81' CJ8 bone stock
Blthomas is offline
post #11 of 14 Old 02-10-2009, 11:13 AM
John Strenk
1976 CJ5
See, I did get the threads mixed up.
post #12 of 14 Old 02-10-2009, 12:47 PM
texasdave
texasdave's Avatar
1980 CJ7
John your age is starting to show
texasdave is offline
post #13 of 14 Old 02-12-2009, 07:54 PM Thread Starter
Blthomas
Blthomas's Avatar
1979 CJ7
All set now, after putting a new ground strap on the bolt, and trying to jump it, I was thinking maybe I got a bad fan motor.
I decided to check the fuses, although when looking at them with the flashlight they looked OK the other day.
Well the fan fuse, one peg was completely whitened from age/corrosion.
New fuse in and the fan came on and about blew me out of there.
Crossing this off the list and moving forwards. Thanks for all the help.
81' CJ8 bone stock
Blthomas is offline
post #14 of 14 Old 02-13-2009, 03:00 AM
John Strenk
1976 CJ5
Well Thats great! Congradulations
WHAT? SPEAK UP SONNY!
Heater Blower motor upgrade napoleoneight Jeep CJ Forum 84 01-10-2015 04:12 PM
Heater blower motor dustbag Jeep CJ Forum 15 10-17-2009 07:11 AM
Blower motor upgrade ? Fuzz21 Jeep CJ Forum 7 09-25-2007 04:58 AM
heater core/motor replaced kymtnman Jeep CJ Forum 2 10-18-2005 10:12 AM
Heater blower upgrade and question.... dali555 Jeep CJ Forum 4 12-30-2004 08:33 PM
