Quantcast Determining amount of Lift on CJ5 ?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Determining amount of Lift on CJ5 ??
Spartan Lockers FREE SHIPPING Excellent PricesFree Shipping on TIRES at KrawlOff-RoadBlack Magic Brakes - 5% Off, No Minimum Purchase Required
Old 03-03-2008, 08:31 PM   #1
rculp
1980 CJ5
How do I go about determining the amount of lift on my CJ5?
It came with 36x14.50's on it with a 3" body lift.
I am in the rebuild stage of a full frame off restoration.
Finally done with frame,axles, new brake and fuel lines.
The shackles I removed measure 5.5" from the centers of the bolt holes.
Is there a measurement on spring curve to go by?
This CJ came with a new 4" Superlift lift kit including shocks amd drop pitman arm still in the box.
I am debating whether or not to install it or sell it
I do not want to get into t-case drops or CV shafts.
Planned use, mostly highway and light offroad.
Any advise would be greatly appreciated.
Thanks
rculp is offline   Reply With Quote
Old 03-03-2008, 09:42 PM   #2
bigyearn
1975 CJ5
got any pictures to share??
and are you saying there is just a body lift on it right now with the 36's?
bigyearn is offline   Reply With Quote
Old 03-03-2008, 09:54 PM   #3
rculp
1980 CJ5
I have a bunch of pics, not sure how to post them.
I think that there must be some lift in the springs as well the 3" body lift to accomidate the 36's.
The link from the pitman arm is at a pretty steep angle, 3-4" above the parallel line of the centerlink.
How do I post some pics?
Old 03-03-2008, 10:05 PM   #4
peanutfarmer101
1978 CJ7
I think the standard shackle is 4" center to center. Yours is 5.5"..1.5 longer than stock...therefore they give you 3/4 " of lift that way. Are the springs still under the axle? Fill in your jeep info so we know more about it....
Its probably already got a 4" kit under it..........I've got a 4" kit and run 33's easily
4" suspension + 3" body + 3/4" shackles ???? Thats my uneducated guess.......anyone else?
Did I say 4"ctc??? I meant 3"ctc.....Sorry, it was late
That makes them 2.5" longer than stock, 1 1/4" of lift...
Peanutfarmer101
'78 CJ-7..304 T400.. 30 up front, locked 20 in back(1 piece axles)..Quadratrac w/ parttime conversion..4" lift w/Currie greasable shackles..33" AT's on 15x12 alum wheels
peanutfarmer101 is offline   Reply With Quote
Old 03-03-2008, 10:09 PM   #5
stephens_cj5
1981 CJ5
I have just about three inches of lift on my CJ5 and I run 33x12.5 and they are look and feel right no rubbing but then again my procomp doesn't seem to have that much articulation.
If I were you I would get rid of the body lift and install the superlift.
1981 CJ5 ground up restro in progress, finished product will have: 4.2 w/ a 4.0 head conversion, headers, Howell TBI, HEI, D300, AMC 20, D30, 3" lift w/ 33x12.50 BFG. All new hardware, all diffs rebuilt.
stephens_cj5 is offline   Reply With Quote
Old 03-03-2008, 10:22 PM   #6
rculp
1980 CJ5
GOT PICS!!
http://i270.photobucket.com/albums/jj87/jrculp/80%20CJ5/80CJ51.jpg
http://i270.photobucket.com/albums/jj87/jrculp/80%20CJ5/80CJ551.jpg
http://i270.photobucket.com/albums/jj87/jrculp/80%20CJ5/80CJ558.jpg
Old 03-03-2008, 10:38 PM   #7
rculp
1980 CJ5
I installed the shocks that came with that 4" Superlift and as you might be able to tell from the pics, they are too long. I only have about 4" of travel before they bottom out.
With the weight of the engine and tranny, they lose another inch.
Is there a way to measure the springs?
Old 03-03-2008, 10:49 PM   #8
bigyearn
1975 CJ5
de clickied
Old 03-03-2008, 10:49 PM   #9
rculp
1980 CJ5
Can I install the 4" lift without getting into t-case drops or cv joints?
Old 03-03-2008, 10:51 PM   #10
rculp
1980 CJ5
Thank you !!
Old 03-03-2008, 10:51 PM   #11
jeepskate
You've got a 1 1/4" shackle lift (stock shackles are 3" hole to hole, not 4") plus a 3" body lift...the springs look like they may be stock, definitely no more than 2 1/2" lift. 36" Swampers don't make for good highway tires...plan on dropping down to the 32"-33" range in an AT or milder MT tread, radials of course. I'd lose the lift shackles, it'll improve your highway handling & stability and consider running wheel spacers for additional stability as well as an anti-sway bar.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
http://www.jeepskate.net
jeepskate is offline   Reply With Quote
Old 03-03-2008, 10:54 PM   #12
rculp
1980 CJ5
Thanks, Bigyearn
How do you do that?
Old 03-03-2008, 10:57 PM   #13
bigyearn
1975 CJ5
Your welcome.
you have to have 50 posts and be a member for a month to post pictures.
Here is my cj5 with 2.5 lift leafs (rancho) and 1/2 lift daystar shackles.
I second the lift shackles not being one of the best things to do if you ride on public roads or use your rig for daily driving.
4 inch with the 32-33's would be sweet!!
Old 03-03-2008, 11:06 PM   #14
rculp
1980 CJ5
Jeepskate,
I appreciate the info.
I am going to sell this one as soon as I am done. So not much highway use or any other with this one for me.
I just got my hands on a great running all orig 79 CJ5 w/304 that I can't wait to get into.
What kind of issues will I get into with the 4" Superlift?
I agree that it needs a swaybar. I've been looking for one.
What length disconnects will I need with the 4" lift?
Old 03-03-2008, 11:11 PM   #15
rculp
1980 CJ5
Bigyearn,
Nice Jeep, and man I sure miss those open spaces.
Glock Forum
