Degree Shim to Fix Caster and Pinion Angle - JeepForum.com
post #1 of 19 Old 11-01-2013, 08:51 AM Thread Starter
dirtyb
1981 CJ8
Front:
So my Jeep CJ-8 came from the PO with ridiculously long shackles (6 1/2" bolt to bolt) on the front and rear. The steering was seriously dangerous. I didn't bother measuring the caster at this point, because I knew it was wrong. I removed the shackles and put stock on. With the stock shackles, the front caster was 4 degrees and the steering was fine. I did some quick trigonometry, and figured that a 6 degree shim along with the 6 1/2" shackles would put me back at 4 - 5 degree caster. I added the shims, but now find my caster angle is only 2 1/2 degrees. Steering is not quite the way I'd like it. It's manageable, but could be better. My plan is to replace the front shackles with 5".
How did my math get messed up? I measured the length of the springs to be 43 inches. If I added 3 1/2 inches of shackle length, then
Tan (theta)= opp/adj = 3.5/43
theta = 4.7 degrees
Caster angle = (what you had stock) + (what the shim should add) - (change induced by longer shackles)
Caster angle = 4+6-4.7 = 5.3
But that's not what happened. I should have a caster of 5.3, but I'm measuring 2.5.
Did I put this stupid thing on correctly anyway?
dirtyb is offline
post #2 of 19 Old 11-01-2013, 08:59 AM
jeepwhore
The massive picture makes it a bit hard to see, but you have the shim installed in the wrong place. Shims go between the leaf pack and axle perch and typically have the thick end towards the front. Where you have it will do nothing except change the angle of the u-bolt plate.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #3 of 19 Old 11-01-2013, 09:17 AM Thread Starter
dirtyb
1981 CJ8
Not to sound like a smart aleck, but are you sure it goes on top of the springs? I thought about it, and didn't install it that way because the shim would start to cover up the round head of the bolt if I did it that way. Am I making sense? If it's installed at the bottom, the way I did it, the round head of the bolt fits into the circle under the perch and there's full engagement. If I put the wedge on the top, the wedge will cover up some of the head of the bolt. Maybe it's not enough to matter?
On the other hand, it makes perfect sense that I'm only rolling the plate.
dirtyb is offline
post #4 of 19 Old 11-01-2013, 09:22 AM
CSP
x2 on the shim location. It goes between the spring and the axle.
CSP is offline
post #5 of 19 Old 11-01-2013, 09:24 AM
jeepwhore
Positive. Think of the springs as a static part of the frame when the jeep is at rest. The caster was rotated by altering the spring orientation via the shackles. The only way to adjust the caster back is by altering the point of contact between the springs and axle perches.
That said, use quality steel shims that are meant to be bolted to the leaf pack.
post #6 of 19 Old 11-01-2013, 09:27 AM
Texian
1978 CJ7
Originally Posted by jeepwhore View Post
Positive. The caster was rotated by altering the spring orientation via the shackles. The only way to adjust the caster back is by altering the point of contact between the springs and axle perches.
What jeepwhore said.
Solid advice that could save your life and your Jeep too.
Texian is offline
post #7 of 19 Old 11-01-2013, 09:32 AM Thread Starter
dirtyb
1981 CJ8
Well, I got that part right.
DOG GONNIT!
dirtyb is offline
post #8 of 19 Old 11-01-2013, 09:40 AM
jeepwhore
DOG GONNIT!
post #9 of 19 Old 11-01-2013, 09:42 AM
Spieg8
1984 CJ8
Agree with the above. Here's a pic of how shim should be installed;
Spieg8 is offline
post #10 of 19 Old 11-01-2013, 09:45 AM
Texian
1978 CJ7
DOG GONNIT!
Glad to see you could get part of it figured out anyway.
Texian is offline
post #11 of 19 Old 11-01-2013, 10:56 AM
JeepHammer
Running On Empty...
1973 CJ5
The first thing I see is...
Spring Shims correct pinion angle.
Caster is corrected with ball joint offset bushings (Up to 1.5 Degrees) or grinding loose the outer axle tube 'C' and repositioning it for correct caster angle...
To try and correct BOTH pinion angle and caster with wedges at the springs probably won't get you where you are going, especially if you have taller tires than stock...
Taller tires require more caster to center correctly, so that multiplies the issues...
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #12 of 19 Old 11-01-2013, 11:31 AM
CSP
People use shims all the time to correct caster. It may not be the most correct method, but the reality is that most go this route for DIY caster correction.
Pinion angle will suffer, but caster takes precedence over pinion angle, especially on a front axle that doesn't have the front driveshaft spinning at highway speeds most of the time anyhow.
CSP is offline
post #13 of 19 Old 11-01-2013, 01:58 PM Thread Starter
dirtyb
1981 CJ8
That's the way I look at it. The pinion angle for the front drive shaft doesn't need to be perfect. I'm in 4x4 mode maybe 5% of the time, and then never at high speeds etc. If this was a professional mud riddin' buggy, I'd change my answer.
Also, I read somewhere that taller tires accentuate whatever type of caster (either positive or negative) that you have. If the world was perfect and tires didn't deform, then tire size wouldn't affect the "feel" of caster. However, since a bigger tire leaves more of an instantaneous footprint, if your caster is in the right direction, a bigger tire makes it "feel" like you get even more caster. If your caster is in the wrong direction, a bigger tire makes it "feel" like you even worse off than before. If I understand correctly....
dirtyb is offline
post #14 of 19 Old 11-01-2013, 02:00 PM
CSP
You understand the concept of caster and bigger tires correctly. The moment arm becomes longer as the diameter of the tires increases.
CSP is offline
post #15 of 19 Old 11-01-2013, 02:14 PM
JeepHammer
Running On Empty...
1973 CJ5
CSP, you are correct that 'Most People' would use just shims...
I'm not 'Most People' and I hate the wear/vibration that comes from the front drive shaft/U joints when the pinion angle doesn't match the angle out of the transfer case.
Once I get rid of that vibration, wear and potential failure point,
Then I move to caster and correct it, since I like to go down the highway at 55 or 60 without taking my life into my hands or hitting a bump and having bump steer make involuntary lane changes on me!
The *FIRST TIME* I did weld grinding to fix caster I was scared to death of it...
Now it's a snap and my oversize tires/lift kit go down the road without a white knuckle grip on the steering wheel!
Wish I would have done it MUCH sooner.
Offset ball joints, caster shims *Might* get your caster back once you shim pinion angle to kill vibration, but it won't do a thing for steering geometry that lift shackles screwed up... Or in my case, too much spring lift and tall tires and it's habit of bump steering...
Lowered pitman arm, reasonable caster made all the difference...
YUP!! I did EVERYTHING WRONG at least three times before I gave in and did it 'Correctly'... Which scared the crap out of me but really wasn't that hard...
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
