A dead horse (Weber tuning trouble) - Page 2 - JeepForum.com
post #16 of 29 Old 02-21-2013, 06:05 PM
swatson454
1983 CJ7
Originally Posted by chevelle383 View Post
In your picture it looks like one of yours is larger than the other? what the heck...mine are same size.
Yep, the one on the valve cover side is a fatty.
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is online now
post #17 of 29 Old 02-21-2013, 06:09 PM
cj5huntingrig
1974 CJ5
Dude...Slow down and take a breath. Buy Redline Weber specific jets most likely from online source or from Redline directly.
That is if yours is a true Redline Weber Carb. Some of the Webers out there are not made by Weber. In that case, I would try to get my money back.
Evan
1974 CJ5 all stock except for Rocky Road SOA
Completely for hunting - not for show or rock climbing
cj5huntingrig is offline
post #18 of 29 Old 02-21-2013, 08:42 PM Thread Starter
chevelle383
1983 CJ7
Its a used weber...ie: Original weber before redline, made in italy. So....mine is definitely small on both sides. Any suggestions??
chevelle383 is offline
post #19 of 29 Old 02-22-2013, 08:38 AM
swatson454
1983 CJ7
I've either gone full-retard on you (which wouldn't surprise me) or someone fubared your carb. This exploded view doesn't provide much clarity because it shows the same jet prefix number for both jets but does clearly state that there is a large and small jet holder. The jet links also show primary and secondary. Exploded view.
Shawn
post #20 of 29 Old 02-22-2013, 09:06 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
My 32/36 idle jets are definitely two different sizes.
Matt
Matt1981CJ7 is online now
post #21 of 29 Old 02-22-2013, 10:44 PM Thread Starter
chevelle383
1983 CJ7
Ya I did a little more research, some of the Original Webers were BOTH the small idle jets. Bummer but in theory I just need a 75 secondary idle jet in my primary...who knew. Ill be sure to follow up for others.
post #22 of 29 Old 02-22-2013, 11:16 PM Thread Starter
chevelle383
1983 CJ7
The other awesome thing I did was I rebuilt the carb while I was waiting for the new 75 jet. And I was blowing out passages and SHOT one of the emulsion tubes clear across my shop....CANT find it anywhere. So I need a new one, what size ? I DONT KNOW! hahaah man oh man. Heres the thing, Im sure this came off of a smaller car, so now on the 258 I probably need to swap ALL the jets and emulsion tubes to larger. Anyone have a full setup of what sizes work on the jeeps? Ill need Main jets, Idle jets (75/60),air corrector jets and emulsion tubes?
post #23 of 29 Old 02-23-2013, 05:16 AM
Matt1981CJ7
1981 CJ7
Your jetting will be largely dependent on elevation, and the condition of your engine. What works for Vinny down in Florida, will run pig rich for Wayne in Colorado.
You should be able to get an assortment in a jetting kit, then just experiment. Many of us like the F7 emulsion tubes, but jet and ac sizes will vary.
Matt
post #24 of 29 Old 02-23-2013, 08:10 AM
swatson454
1983 CJ7
Air-launched an emulsion tube, huh? That sucks.
If it were me, I'd leave the existing a/c jets in their current locations but use an F-6 in the primary side and an F-7 in the secondary. You might have to drive-test it for a bit to see if the primary side wants the F-6 over the existing F-50 but I suppose it will.
I can't remember a good starting point on your main jets, however. What are they now?
Shawn
post #25 of 29 Old 02-23-2013, 12:33 PM Thread Starter
chevelle383
1983 CJ7
The "Remaining" Emulsion tube is an F50 the other is somewhere in the space time continuum. Main Jets are 140/140 and the air corrector jets are 170/160. My elevation is 2700' high desertjust incase eithje rof you guys are similar.
post #26 of 29 Old 02-23-2013, 12:42 PM Thread Starter
chevelle383
1983 CJ7
And a picture of the Idle Jets/holders. Same size, weird huh? I inspected where it threads in on the primary side half expecting a "modification", but it's definitely stock from weber.
post #27 of 29 Old 02-23-2013, 12:43 PM Thread Starter
chevelle383
1983 CJ7
Whoa..sorry for the GIANT picture, I resized it in half, guess that's not enough lol. So at the bottom of the page on http://www.carburetion.com/diags/3236DGAVDiaginfo.asp it shows the stock setup from weber, which matches mine perfectly.
post #28 of 29 Old 03-03-2013, 12:45 PM Thread Starter
chevelle383
1983 CJ7
SUUUUURE does idle pretty now However skips and stutters under acceleration. Lean or rich assuming all else is well?
post #29 of 29 Old 03-03-2013, 04:19 PM
86cj74.2L
86cj74.2L's Avatar
Or ignition related.
86cj74.2L is offline
