**DD rigs only** how do you use 4wd on winter roads - JeepForum.com
post #1 of 19 Old 12-19-2008, 12:02 PM Thread Starter
twmattox
A different thread got me thinking about this:
Around here, I use my part time (Dana 300) 4wd only when the roads are fully ice/snow covered. I know that dry pavement can kill the t-case. However, is it safe to use on roads that are mixed slush covered, wet pavement, snow cover? How much dry pavement does it take to bind a T-case? If I am cruising along and hit a patch of 300' dry pavement, will the rig grenade???
twmattox is offline
post #2 of 19 Old 12-19-2008, 12:31 PM
hh65flyer
Check out the "How Fast is Too Fast" active thread. I think your questions will be answered.
1984 CJ7, 2nd owner.
360 V-8, T-176 and Dana 300.
D30/D44...Aussie/Lock-Rite
33" BFG Mud-Terrains, 1/2" shackle, 2" spring lift.
Vehicle weight reduction program: Rust!
hh65flyer is offline
post #3 of 19 Old 12-19-2008, 12:35 PM
Gunga
1978 CJ7
If you maintain a straight line you'll have less chance of damage. Turning your wheels on dry pavement in 4wd will cause problems.
'78 CJ-7, 401 w/ headers, T-18, 35" muds, 4" lift, MSD ignition box, locked diffs.
Gunga is offline
post #4 of 19 Old 12-19-2008, 12:42 PM Thread Starter
twmattox
The how fast is too fast is the thread that got me thinking. Rather than hijacking that thread...I started a new one.
twmattox is offline
post #5 of 19 Old 12-19-2008, 12:48 PM
RenegadeKing81
1981 CJ7
I don't think that 300 feet will do anything to the T-case. Turning the vehicle on dry pavement while in 4wd may. With part time 4wd set ups the tires can spin at different speeds while turning. Full time 4wd rigs don't have this issue. This isn't much of an issue while off road due to the tires not being able to grab the surface as well as they would on a dry road. So, as far as hitting a dry patch of road in the snow I wouldn't worry too much about it. Nor would a turn here or there cause too much of an issue. I just wouldn't keep in four wheel drive when it is just a little wet out there.
I see that you are in Indiana, did you get the same ice storm that we had here in Illinois?
1981 Renegade AMC 304 w/35's
1997 SE 2.5 w/31's
2000 4.0 w/33's
2005 GC 4.7 stock
RenegadeKing81 is offline
post #6 of 19 Old 12-19-2008, 12:51 PM
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
Just switch to 2hi for the dry section then back to 4 hi when you get to snow/ice covered. A little practice and it becomes almost second nature, just like shifting gears. Good Luck, it's Sunny and 81* here
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #7 of 19 Old 12-19-2008, 03:23 PM
243
1978 FSJ Cherokee
You have never shifted my D300...all I can say is she's a b@&$!
Dave's 78 Build
243 is offline
post #8 of 19 Old 12-19-2008, 05:03 PM
tomthbomb
CJ7 1/2 Top Club mem. #1
tomthbomb's Avatar
1978 CJ7
Back in 1978 when my CJ-7 was still pretty new I drove 20 miles to home with the D20 in 4wd.
I drove it with the D20 for another 25 years without any problems before I swapped in the D300.
Your mileage may vary and no cold beer was involved on that occasion.
1978 CJ-7 original owner; AMC 401 V-8 (w/some goodies);NP4500;D300 (w/Curry 4:1); D44 front;AMC20 (Warn one piece axles) rear
tomthbomb is offline
post #9 of 19 Old 12-19-2008, 05:10 PM
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
I've read alot of your posts, so I'm pretty sure the answer is yes, but have you changed your T-case fluid lately. Made a huge difference for me with the D300.
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #10 of 19 Old 12-19-2008, 05:26 PM
pscj5
1972 CJ5
as on the other forum page it wont die even if the pavement is dry not for short periods of time just dont be goin 80 lol that prolly not even posible but lower speeds in 4wd hi wont kill a tcase now if you are makin bunch of u turns i may switch out of it but other than that mild turns wont hurt you or even stretches of just moist road. but good luck
If you get stuck it better be broke or you didnt hit it hard enough
pscj5 is offline
post #11 of 19 Old 12-19-2008, 07:22 PM
John Strenk
John Strenk's Avatar
1976 CJ5
I just slip mine in and out of 4WD as I start to feel it bind up. Since the roads are pretty bad when I'm out plowing I use 4WD a lot in the winter. It also seems to help with my braking.
300 feet won't kill it at all.
John Strenk is offline
post #12 of 19 Old 12-19-2008, 08:46 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
X2. Simply leave the hubs locked in and pop the t case in and out as needed.
jeepdaddy2000 is offline
post #13 of 19 Old 12-22-2008, 09:08 AM Thread Starter
twmattox
This is what I typically do. However, I have to reach for the 4wd shifter and don't want to do it 50+ times for a drive home (as I drive this daily).
As far as making the shift easier. If you accelerate as you shift into 4wd and decelerate as you shift back into 2wd it makes it significantly easier to shift. The decelerate is not simply a lifting your foot off the gas...more like goosing the gas and as you are letting off of the gas, shift...
As far as the ice storm. Yes, we got hit. Fortunately, not as bad as friends further north. Our ice was followed by rain a few hours later and the rain got rid of all the ice...
twmattox is offline
post #14 of 19 Old 12-22-2008, 12:51 PM
VaCJ79
1979 CJ7
how long can you drive around with the hubs locked in 2H? Where I am its bad in town but the roads outside of town are for most part clear.
1979 CJ7 258 / 4.0 head / J20 power Steering / T150 Dana 20 / EMU YJ 2" lift / Custom front bumper
Looking for : Please PM, Carter 2 barrel Carb before you through it out
VaCJ79 is offline
post #15 of 19 Old 12-22-2008, 02:17 PM
druxus
1978 CJ5
For the past couple of years the snow has been bad here on Michigan's west coast. I DD a 72 cj5 80 miles to work and back home with hubs locked and half the time in 4x4 with no problems.
We got slammed good here in Muskegon ... about 2 ft worth since last friday and more predicted most of the week
druxus is offline
Streetable trail rigs... Whats it take ? Bruner3 Jeep CJ Forum 3 11-14-2009 09:38 AM
at the cross roads gdepley Jeep CJ Forum 17 03-08-2008 08:15 AM
Who makes Custom Jeep Rigs portocar Jeep CJ Forum 2 06-06-2007 02:14 PM
Gravel roads MeCasa Jeep CJ Forum 27 03-24-2006 11:11 AM
mt's on wet roads 2cjs Jeep CJ Forum 1 03-08-2004 12:54 PM
