Dave's 83 CJ7 Build - Page 10 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Dave's 83 CJ7 Build
NOTCH CUSTOMS - Max Clearance Fender FlaresIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineROCKRIDGE 4WD Supports our Service Members! Military Disc
Unread 12-01-2009, 02:17 PM   #136
danheit
1979 CJ7
just FYI, that is a Hi-Lift, not a crappy old farm jack. Good score! Been loving this build. You have inspired me to think about doing something to the Jeep!
I NEED A SINGLE 15X8 MICKEY THOMPSON OR SIMILAR ALUMINUM BULLET HOLE WHEEL!!!!
Build Thread: 1979 CJ7 Blue Jeep
danheit is offline   Reply With Quote
Unread 12-01-2009, 05:01 PM   #137
shortgoroper
1983 CJ7
Good day shopping.. Let me know how your shop press turns out... Snap a picture of it then.
shortgoroper is offline   Reply With Quote
Unread 12-01-2009, 09:21 PM   #138
243
243's Avatar
1983 CJ7
I spent a few hours in the garage cutting the pieces for the shop press while it rained rather than sitting behind the computer. I wanted the press to be at least 65" tall but I was short one piece of 3" channel so the width between the verticals would only be 14".
I made them 59" tall with 16 1/2" clear between them. If it quits raining I will clean them up tomorrow and start putting it together.
1983 CJ7
258/T177/D300 3.54 32" BFG KM2
THE BEGINNING:
http://www.jeepforum.com/forum/f8/da...2/#post8211912
In the 80's we had Reagan, Bob Hope, and Johnny Cash
Now we have Obama, no Hope, and no Cash
243 is offline   Reply With Quote
Unread 12-02-2009, 02:32 PM   #139
shortgoroper
1983 CJ7
How did you drill your holes for the height adjustment??? Drill Press or Plasma Cut them???
Unread 12-02-2009, 04:43 PM   #140
243
243's Avatar
1983 CJ7
All drilled, took less than an hour using 3/8", 1/2" and then 3/4".
1983 CJ7
THE BEGINNING:
Unread 12-02-2009, 06:36 PM   #141
shortgoroper
1983 CJ7
Ok.. wasnt thinking when I asked that.. I guess the holes have to be drilled on a press so that they are plumb and square.. otherwise the pressing could be off canter. Duh.. Keep up the good work.. Following along every step.. I just got an 83 this past fall.. Its sitting under the carport ready to be moved into the garage for the overhaul. I just needed to get the shop set up first.. I will be all done come the 1st of the year. Good Job!
Unread 12-04-2009, 02:08 AM   #142
00bluedak
awesome build man!!!
subscribed!!!
Dave Thomas
President, Currahee Jeeps Club
WWW.CURRAHEEJEEPS.COM
00bluedak is offline   Reply With Quote
Unread 12-06-2009, 03:11 PM   #143
243
243's Avatar
1983 CJ7
I was able to get back to the shop today with the intent of finishing the press. I lopped off the corners of the 3X3 angles I am using for the feet. The lopped off corners will be less painful to my kneecaps when I forget and kneel down to get a better look at what I am working on. I wire wheeled and de-burred the steel and started laying out the main rails checking for square.
I welded the double channels at the top of the press frame flush with the vertical channels leaving a gap in the middle. I was not sure how I was going to attach the return springs so I though this was the safe way to do it.
I welded two pieces of 1x1 angle iron between the C4 channels and it would not fit between the vertical rails. I cut it apart, double checked the dimension between the vertical rails and welded in two pieces of 1 1/2" square tubing.
I cut two pieces of C4 to make the ends of the jack rail.
I mocked up the jack rail, springs and eyebolts to see how it fit. OOPS looks like my idea to use the C4 for each end of the jack rail left just a little too much slop...on to plan B.
I found some 1 1/4" and 1 1/2" square tubing in the scrap pile and welded in some guides and modified the eyebolts with a BFH so they would fit inside the 1 1/4" tubing. I like the cleaner look of the hidden springs. It was a PIA getting it fit up correctly but it works good now.
I cut a piece of cold roll to length for the ram, put it in the press and then flipped it upside down to weld it in place.
Almost finished, I still need to weld in a top plate with a hole for the jack ram, weld a support between the 3X3 angles, get some Grade 8 bolts or some hitch pins, cut some notches in the arbor plates and prime and paint it.
But for now I can get back on the D30 axles...this was a fun project.
1983 CJ7
THE BEGINNING:
Unread 12-06-2009, 05:23 PM   #144
Exposed
Exposed's Avatar
1981 CJ5
Looks great David.. Looks real similiar to the one in my shop.....
Exposed is offline   Reply With Quote
Unread 12-06-2009, 09:56 PM   #145
shortgoroper
1983 CJ7
Nice Press... Will save you some time by not having to run to your Uncle's
Unread 12-07-2009, 01:18 PM   #146
34kw
Nice job on the build and the thread! Makes me want to go dismantle my 1980
34kw is offline   Reply With Quote
Unread 12-07-2009, 07:25 PM   #147
adhdlacrosse16
this is awesome subscribed
99' WJ... tank raise mesh grill homebrew cai
magnaflow 11226, banks header, bb sittin on 31s
adhdlacrosse16 is offline   Reply With Quote
Unread 12-08-2009, 05:06 AM   #148
243
243's Avatar
1983 CJ7
Thanks guys...
I don't think I will get much done for the next few weeks due tor Xmas and New Years. I do plan on installing the u-joints and painting the D30 axles.
If I have time this weekend I will install the crank and pistons in the block. I have not built a motor since 1985 so this will be another fun project for me. I thought about taking the block and head to the carwash but I am going to look for a hose adapter for the kitchen faucet, I have the hot water heater turned up to max and it is HOT as hell.
1983 CJ7
THE BEGINNING:
Unread 01-14-2010, 09:19 AM   #149
markey006
what happened? any updates?
markey006 is offline   Reply With Quote
Unread 01-14-2010, 12:27 PM   #150
XJisTHErightWAY
I second that. All but forgot about this great build until it got bumped. We demand updates!
[QUOTE=hussler737;8317259]
I had a hot girl on facebook say "nice jeep, but i've always wanted a wrangler" and my response was deleting her from my friends list.[/QUOTE]
XJisTHErightWAY is offline   Reply With Quote
