Dashpad repair - JeepForum.com
post #1 of 15 Old 03-22-2010, 05:28 PM Thread Starter
84MSRB
Dashpad repair
So- is filling cracks with JBWeld and sanding the normal way to fix cracked dashpads? (I searched and found Fatmans shots)
If that works- what paint (Krylon?) is best?
1984 CJ7 Mud Slingin Rust Bucket
90 YJ tub
Ford Mutt 5.0( 69 block, 89 EFI)
84MSRB is offline
post #2 of 15 Old 03-22-2010, 05:38 PM
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
For paint I would reccommend Dupli-color Vinyl and Fabric It bonds like super glue and has never faded, peeled or cracked on anything I've ever used on.
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #3 of 15 Old 03-22-2010, 06:38 PM Thread Starter
84MSRB
Cool. Hope they got a shade of Spice in between the Spice Seats and Spice sunvisors that ain't the same shade of spice.
90 YJ tub
84MSRB is offline
post #4 of 15 Old 03-22-2010, 09:27 PM
Skerr
Glad you asked tihs question... I have this to do too. Can you post some before and after pics?
Kerrdog
Go Fish! <*////><
Skerr is offline
post #5 of 15 Old 03-23-2010, 04:28 AM Thread Starter
84MSRB
No problem.
90 YJ tub
84MSRB is offline
post #6 of 15 Old 03-23-2010, 08:46 AM
wm69
SEM "camel" is a pretty good compromise. I have a spice Supertop with a honey interior. I painted my Tuffy console, laredo leather wrapped grab bar, and my door panels all with the SEM stuff and it looks good.
wm69 is offline
post #7 of 15 Old 03-23-2010, 08:55 AM Thread Starter
84MSRB
Excellent- now I can round up everything and get it done this weekend. Maybe. Probably gotta sand and rustoleum the little mounting tab doodads while I'm at it.
90 YJ tub
84MSRB is offline
post #8 of 15 Old 03-23-2010, 09:09 AM
JoonHoss
2011 JK Wrangler
look up JF member FATMAN, and find (IIRC) his rollbar thread/ project cage. he cut his dashpad to fit around the rollbar, and has good pics and descriptions on how to make it look new again
EDIT: here you go
http://www.jeepforum.com/forum/f8/project-cage-450100/
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is online now
post #9 of 15 Old 03-28-2010, 10:55 AM Thread Starter
84MSRB
Sorry- the camera was dead when I went to the garage, so I went ahead and slathered up all the cracks with JBWeld- really pushed it in- I think. Gonna let it cure and sand it a while, we'll see if it works.
90 YJ tub
84MSRB is offline
post #10 of 15 Old 03-28-2010, 11:08 AM
BioTex
1979 CJ7
I was getting ready to repair a dash on my Scout II, and was planning to use Fiberglass hair mixed in with bodo. Any reason to use JB weld vs. the fiber?
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #11 of 15 Old 03-28-2010, 11:57 AM Thread Starter
84MSRB
Let me start by saying I really don't know what the hell I'm doing. I followed Fatman's build, and he used JB on the ends of his dashpad, to seal up the foam so it could be painted (I think). My dash pad has several weathered cracks, where the hard vinyl actually curves up away from the crack. My thoughts are to force so much JB down into the foam that I can sand it down when it cures.
But if this doesn't work, I'm OK with no dashpad.
90 YJ tub
84MSRB is offline
post #12 of 15 Old 03-29-2010, 08:30 AM Thread Starter
84MSRB
Obviously, forcing the JB into the foam is key. If you don't, it just all pops off and you're right back where you started. Pics later.
90 YJ tub
84MSRB is offline
post #13 of 15 Old 03-29-2010, 09:46 PM
gtracy
1981 CJ5
I'm doing the same thing as Fatman, accept for that my corners were cracked as well. Did the JB Weld and sanded smooth. Ready for a second coat to build up some torn areas. Seems to be working well.
gtracy is offline
post #14 of 15 Old 03-29-2010, 10:42 PM
shok47
1983 CJ7
I would also appreciate pics and a write up! I picked up one for $25 and it only has one gash in it.
shok47 is offline
post #15 of 15 Old 03-30-2010, 05:31 AM Thread Starter
84MSRB
Got no before pics- all I have is some cracks. Problem: old cracks, vinyl is curved up at the edge of the crack, and flexes every time you try to force JB in.
My solution: remove the curled up vinyl- that will give you the exposed foan, much as Fatman got when he cut off those little ends.
I will get some pics of this operation.
90 YJ tub
84MSRB is offline
Is this dashpad salvageable? Daladim Jeep CJ Forum 7 12-31-2009 09:43 PM
How would you repair this? crawdad Jeep CJ Forum 10 04-28-2008 07:30 PM
removing the dashpad... ttrem Jeep CJ Forum 2 06-29-2006 05:06 PM
Cj Dashpad 84laredo Jeep CJ Forum 8 04-13-2004 12:21 PM
how to remove a dashpad? aufderheide Jeep CJ Forum 2 02-22-2004 02:17 PM
