Dash switches - JeepForum.com
post #1 of 5 Old 07-11-2013, 01:19 PM Thread Starter
Rjax
1980 CJ7
Dash switches
Ok, here is my issue. I have a stainless steel dash that I installed. It had all switches and heater cable holes pre cut the rest blank. I wanted it blank so I could place after market gauges in the config I wanted. The problem that I am now getting around to is the holes for the headlight, fan motor, and wiper switch is completely round. The holes do not have a flat side to prevent switch housings from turning. I was thinking of just using an epoxy or jb weld to build up flat side. But, was wanting to pick the forums brain and see if you guys know of any other fix.
RJ
Rjax is offline
post #2 of 5 Old 07-11-2013, 01:45 PM
HardworkWorks
Weld in little pieces for flat sides
HardworkWorks is offline
post #3 of 5 Old 07-11-2013, 01:50 PM
agear
I'm just brainstorming here but is the flat part on the switch stud not just there to keep it from spinning while tightening the nut thing ? If you just tightened it down it would still move ?
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #4 of 5 Old 07-11-2013, 01:59 PM
2girlsAndaGuy
1979 CJ5
seems the switches on my dash hold just fine in a round hole, so long as the nut is tightened down good.
David
2girlsAndaGuy is offline
post #5 of 5 Old 07-11-2013, 03:12 PM Thread Starter
Rjax
1980 CJ7
Thanks for the replies. I tightened the nuts pretty snug and they turned. I'll try wrenching them down some more.
Rjax is offline
