dash panel: to cut or not to cut? - JeepForum.com
post #1 of 12 Old 01-21-2010, 12:49 PM Thread Starter
Matt_G
1979 CJ5
I'm dissembling my jeep to get ready for paint.
right know I've got everything out of the dash and i'm pretty sure i want to take the dash off since that will make masking about 1,000 times easier.
problem is i have a tilt column and i can't figure out how to get down to that lever to remove it. I've only been as far as that spring that holds the lock plate on.
an easier solution is just to cut a hole where the column is and pull it up.
what do you think.
Matt_G is offline
post #2 of 12 Old 01-21-2010, 12:53 PM
jds79cj
The other option is to to pull I wanna say about 6 bolts and pull the entire column from the jeep. Thats what i did and it was pretty simple that will also give you a chance to inspect the column bushings and bearings.
jds79cj is offline
post #3 of 12 Old 01-21-2010, 01:10 PM
Pathkiller
1974 CJ5
The tilt lever unscrews. You don't need to access it through the top of the column.
Pathkiller is offline
post #4 of 12 Old 01-21-2010, 02:54 PM
trailhead2004
1980 CJ7
2x. Unbolt it from the firewall and the dash. Much easier.
trailhead
"Bad things happen to you because you're a dumba$$"
Red Foreman
trailhead2004 is offline
post #5 of 12 Old 01-21-2010, 03:26 PM Thread Starter
Matt_G
1979 CJ5
OMG, i never even thought of that. i'm an idiot. (actually i think i've done it before......wow.
thanks guys
Matt_G is offline
post #6 of 12 Old 01-21-2010, 03:30 PM
CJunk
All you needed to do was pull the steering wheel and unscrew the tilt lever... unless you have an automatic?
CJunk is offline
post #7 of 12 Old 01-21-2010, 03:31 PM Thread Starter
Matt_G
1979 CJ5
know i have another problem. the pull knobs that open close defrost/heat/control temp. how do these come out of the dash. also where they are secured they have some weird fastener that doesn't want to come off. it looks like a snap on a pair of pants? thanks alot!
Matt_G is offline
post #8 of 12 Old 01-21-2010, 03:38 PM
Pathkiller
1974 CJ5
From the backside you will need to squeeze two prongs together and push the knob assembly forward out the front side of the dash. Easy once you figure out what you need to do. You can kind of see them in this pic: http://www.the-jeep-guy.com/Heating%...g%20cables.jpg
post #9 of 12 Old 01-21-2010, 08:40 PM
wrongway92407
wrongway92407's Avatar
It's amazing how we can over look the obvious, we've all been there.
Wrongway
My fleet:
86 CJ7 5.7 vortec. 4L60,D44's,OBA,Air tank bumpers w/D rings detroits,4.88,35" bfg, mt's 9500ti warn
86 CJ7 2.5 detroits, OBA 4.56, air tank bumpers, w/D rings,9500I warn 31x10.5x15, Trxus
86 CJ7 bone stock, w/factory 44 never seen the dirt soon to be for sale
87 Wrangler also never seen the dirt.
wrongway92407 is offline
post #10 of 12 Old 01-21-2010, 09:23 PM Thread Starter
Matt_G
1979 CJ5
anyone know how to get that snap on nut thingy off?
it attaches the cable end to the piece that controls how far the door on the inside opens. if you are wearing jeans and you look at one of your pockets. it has a little metal snap like thing that looks alot like this piece. it is flat on all sides and won't come off with pliers or anything i've tried. i'm about to cut it with a grinder
Matt_G is offline
post #11 of 12 Old 01-21-2010, 10:06 PM
PERK
use short screw driver, get the blade behind it and walk it off. they just press on. don't loose them, there hard to find
PERK is offline
post #12 of 12 Old 01-21-2010, 10:11 PM
PERK
if you don't have a manual alot of the information in this one is the same as yours
http://oljeep.com/gw/82_tsm/Contents.pdf
PERK is offline
CUSTOM DASH PANEL Member jcooley7 Jeep CJ Forum 2 10-31-2009 10:51 AM
M38 Dash Panel dimensions Raccroc Jeep CJ Forum 1 11-14-2008 09:46 AM
Dash Panel and crash pad in CJ-7? cavedweller Jeep CJ Forum 12 06-15-2007 12:21 PM
New Dash Panel cfvol Jeep CJ Forum 10 11-07-2006 05:38 PM
dash panel petey156 Jeep CJ Forum 3 01-27-2006 01:47 AM
