Dash pad or not? - JeepForum.com
View Poll Results: Dash pad yes/no or leave it nekid
Keep it plain 63 56.25%
Get one - it makes it look finished 49 43.75%
to hard to put one on - blow it off 0 0%
Voters: 112. You may not vote on this poll
post #1 of 47 Old 09-04-2011, 11:38 AM Thread Starter
dirt_dobber
1977 CJ7
Dash pad or not?
I am thinking of buying a dash pad - but I'm kind of liking the naked look.
I would like to know the degree of difficulty installing one as well as a yes/no poll.
"Life is tough, it's tougher if you're stupid." Sgt Stryker, USMC (John Wayne)
dirt_dobber is offline
post #2 of 47 Old 09-04-2011, 11:55 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
I never liked them on there. Plus, it's just gonna crack and fade in the sun, so why waste your money?
Rick
Cutlass327 is offline
post #3 of 47 Old 09-04-2011, 12:23 PM
Viencent
1982 CJ7
first thing I took off my cj7 when i got it home
Viencent is offline
post #4 of 47 Old 09-04-2011, 12:54 PM
Chuckles0227
1980 CJ5
I tossed mine, I think it looks better without one
"If you sit when you pee, go with the square headlights..." - tawdr77
Chuckles0227 is offline
post #5 of 47 Old 09-04-2011, 12:55 PM
josh86k10
I actually really like the dash pad... different strokes for different folks I guess. I've been toying with the idea of adding a front bar to the roll bar setup though and the pad looks like it will interfere, just something to think about.
josh86k10 is offline
post #6 of 47 Old 09-04-2011, 12:57 PM
MoC
I love my dash pad...
MoC is offline
post #7 of 47 Old 09-04-2011, 12:58 PM
JeffreyCharles
1976 CJ5
Here's another vote for no pad. I don't have one on mine - like it better without.
Jeffrey Charles
http://jeep.smallcraft.net/
JeffreyCharles is offline
post #8 of 47 Old 09-04-2011, 01:01 PM
whodatsCJ7
1978 CJ7
I like my dash pad
Stay thirsty my friends
whodatsCJ7 is offline
post #9 of 47 Old 09-04-2011, 01:02 PM
agear
It's factory legit and doesn't look bad on there.
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #10 of 47 Old 09-04-2011, 02:04 PM
hp_lovecraft
1981 CJ5
One nice advantage to not having the dashpad is that if your wiper linkage, or motor, should happen to fail, you can pop off the linkage cover, and operate them manually. Plus it gives you more room to attach accessories. (I had a fire extinguisher mounted on the windshield frame).
On a related note, I've wanted to remove my dash panel as well. Do I have to completely remove the heater controls first? I havnt figured out how to remove them yet.... doesnt seem too difficult, but i have a habit of breaking things.
hp_lovecraft is offline
post #11 of 47 Old 09-04-2011, 02:17 PM
agear
On a related note, I've wanted to remove my dash panel as well. Do I have to completely remove the heater controls first? I havnt figured out how to remove them yet.... doesnt seem too difficult, but i have a habit of breaking things.[/quote]
No, you just have to lower the windshield, which means moving the hard top or soft top off a little if you have one on. unless those tabs go under the dash panel, which apparently they do. You can just loosen all the dash panel screws and move it out of the way enough.
A pack of smokes is secure between the dash pad and windshield frame .
agear is offline
post #12 of 47 Old 09-04-2011, 03:49 PM
WoodyHD
1983 CJ7
Why do you need to remove the panel? If you just take it off and lay it down with the one side resting on the steering column then you're good without removing those cables. To take them off you pinch backside and push through front.
I'd leave dash pad off. Looks better IMO. Only reason I got mine is because the dash behind it ain't too pretty, but yours looks great.
WoodyHD is offline
post #13 of 47 Old 09-04-2011, 04:10 PM
boomvader
My opinion: Looks great and Omix has a great licensed replacement available for under $200 shipped.
-boom
Boom's CJ-7 Project (Completed in 2011)
boomvader is offline
post #14 of 47 Old 09-04-2011, 04:37 PM
arkiemurph
If you go topless a lot, you can get some rust issues between the pad and dash. They do make
A nice shelf, though! Good for sitting a cold one on or rifle or whatever!
Murph
Love thy neighbor, but don't mow down the hedge.
arkiemurph is offline
post #15 of 47 Old 09-04-2011, 06:35 PM
cardiffclimber
1981 CJ7
I like the way it looks without. I took mine off when I replace my windshield frame and never regretted it.
"Rule #9.1: Never go anywhere without a jeep."
cardiffclimber is offline
75 cj dash jhartley Jeep CJ Forum 2 04-05-2011 09:25 PM
new dash, can't get light or wiper switch off old dash CJATE Jeep CJ Forum 2 06-29-2009 12:21 PM
New Dash bpal Jeep CJ Forum 23 11-09-2007 11:18 AM
A.E. Miller Dash -n- store replacment dash pad CJ5_Fan Jeep CJ Forum 0 02-23-2005 01:37 PM
CJ 7 Dash Maverick04 Jeep CJ Forum 4 02-29-2004 10:31 AM
