dash lights not working. - JeepForum.com
post #1 of 3 Old 05-08-2007, 02:38 PM Thread Starter
jlutsey
1981 CJ7
none of my dash lights work with the exception of my high beam and my e-brake. what are the odds of all the bulbs being out?, sounds like a ground right? all the fuses aregood. Any ideas?
"If you haven't tried it you should,
these things are fun and fun is good!"
81 CJ 7 Renegade. 304, edelbrock performer intake, Holley 600, HEI, K&N, 33x12.5x15
jlutsey is offline
post #2 of 3 Old 05-08-2007, 06:45 PM
Scrambler82
Scrambler82's Avatar
1982 CJ8
How about start by checking to see if there is power at the Dash Panel and other lights.
If yes then see if the ground is good.
If no then add a temp ground wire and see if this cures the problem.
If yes then make the temp ground wire permanent.
If you get power to some thing and not to others keep checking and adding the necessary grounds or new power wires.
ltr,
Scrambler82
Do it right the first time !
Scrambler82 is offline
post #3 of 3 Old 05-08-2007, 08:29 PM
Mr. Corrosion
I know exactly what your problem is. The dash itself isn't grounding to the body. Check any bolt/screw on the dash with a test light grounded to the tub and you'll probably see that the entire dash panel is hot. You'll just need to either make a grounding strap or remove the dash and clean some paint/corrosion to make a good ground.
I've had the EXACT same problem.
2007 Rubicon 2-door, Red Rock
6-speed, Dual tops
2.5" Teraflex Coil Lift, Shrockworks Mid-Width, Warn M8000
Mr. Corrosion is offline
Dash lights not working in 77 CJ7?? Brownstone77 Jeep CJ Forum 3 10-07-2009 02:57 PM
Dash lights quit working. scottymac62 Jeep CJ Forum 9 06-02-2009 10:24 PM
high beam light working but no other dash lights threefortheshow Jeep CJ Forum 9 11-27-2008 08:18 PM
1979 CJ7 Dash Lights arent working hookntail Jeep CJ Forum 2 09-17-2008 09:11 PM
Dash indicator lights not working onesourcemike Jeep CJ Forum 4 08-11-2008 08:58 AM
