Dash ideas... - Page 5 - JeepForum.com
post #61 of 70 Old 05-13-2013, 01:45 PM
vinnyabs
1983 CJ7
Thanks! Done and done. Now next step of creativity.
Earning an engineering degree one CJ7 hiccup at a time
vinnyabs is offline
post #62 of 70 Old 05-19-2013, 09:35 PM Thread Starter
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Just got this back from Daniel, what do you guys think? Anything you would change?
The center section will stick out about 2.5" on the bottom, leaving plenty of room for all 3 shifters. The 9 square holes will be for Condura switches, and the one on the left will be a regular lever switch with a cover on it, for the radiator fan. The entire panel with the gauges and the switches is on a hinge, so that way I won't have to take down the entire dash to work on something, or crawl underneath and break my back.
Best part about the center section, it will let the defrost ducting stay completely intact.
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline
post #63 of 70 Old 05-20-2013, 04:44 PM
Coiz
1979 CJ7
That's pretty slick. Good call on keeping the pull cables in the stock locations, that is going to make life easier. What is the rectangular box above the column opening for?
Mike
Coiz is offline
post #64 of 70 Old 05-20-2013, 05:07 PM Thread Starter
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Dummy lights! LEDs for turn signals, bright's, parking brake, oil pressure, water temp, and check engine.
Thanks for the input Mike, you helped convince me to use the factory cables.
Andy, KD8EIA
Grewe02 is offline
post #65 of 70 Old 03-27-2015, 04:20 PM Thread Starter
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
2 years later......
Andy, KD8EIA
Grewe02 is offline
post #66 of 70 Old 03-27-2015, 04:24 PM
jeepwhore
Nice!......but won't you need a co-pilot all the time to reach those switches on the far right?
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #67 of 70 Old 03-27-2015, 04:40 PM Thread Starter
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Pretty much. I've hired Kate Upton to fill that position.
Andy, KD8EIA
Grewe02 is offline
post #68 of 70 Old 03-27-2015, 08:29 PM
jeepwhore
Excellent......you have a spot on that side of the dash to mount a go pro with super slow mo........right?
post #69 of 70 Old 03-27-2015, 08:46 PM
jeep_boy02
1980 CJ7
Lol... Now that's a dash! And that for sure is a co-driver!!! And an excellent idea for incab footage
80 CJ7-304/T176/D300 HEI hdrs-WT D30/D44 4.56s, lockright/spool-SOA YJs W/RE AAL-35 MTRs beadlocks
jeep_boy02 is offline
post #70 of 70 Old 03-29-2015, 02:08 PM
agear
Why didnt you just buy a fire truck or an tractor trailer. Just kidding. its a nice dash
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
SPARE Axle Storage Ideas.... any other ideas? Fjguercio Jeep CJ Forum 3 12-10-2009 08:54 AM
custom dash ideas RockScar Jeep CJ Forum 58 07-26-2009 11:31 AM
new dash, can't get light or wiper switch off old dash CJATE Jeep CJ Forum 2 06-29-2009 12:21 PM
SHARE IDEAS!! Need custom exhaust ideas for Chevy 350 Turbo! DWK213 Jeep CJ Forum 3 04-18-2009 08:57 PM
Any Ideas on how to do a custom dash? JasonMonette Jeep CJ Forum 7 01-06-2005 10:17 AM
