Dash ground question - JeepForum.com
post #1 of 5 Old 01-08-2012, 12:20 PM Thread Starter
usmarine3521
Hello all,
So I'm adding some switches and lights to my dash and I'm trying to figure out a good ground. I hav my dash out of the jeep on a bench, and I have grounds to my dash for my lights. Now when I test to see if my lights I put in my dash will work, I get nothing. I heard that I can ground to the dash but the dash grounds to the body. So when I re install my dash will the grounds I have set to my dash work?
usmarine3521 is offline
post #2 of 5 Old 01-08-2012, 12:26 PM
CrazyHorse6
1979 CJ7
If I understand your question, you have installed the lights and then grounded them to the dash while its on the bench? If that's the case, your dash is not grounded at that point so you'll need another temp bench ground for your dash to test the lights- maybe run a wire with alligator clips from the dash to your battery temporarily. Once the dash is back in, you'll have your ground back. Additionally, you can also run a dedicated ground from the battery to the dash for accessories if you like.
CJ7, 258, Dana 20 T-case, Dana 30 & AMC 20, TFI Ignition upgrade, MC 2150 carb, YJ tub mod
CrazyHorse6 is offline
post #3 of 5 Old 01-08-2012, 12:30 PM
KJNewbs
1983 CJ7
Originally Posted by CrazyHorse6
Yes, you won't have a ground until your dash is reinstalled. For testing, just ground it out to something else for now. Once the dash is back in you can also run a dedicated ground from the battery to the dash for accessories if you like.
What he said. I'm in the process of doing a rewire and have run dedicated grounds to my front (for headlights), my dash (for gauges, etc) and to the rear (for taillights and fuel sender).
This way I know my grounds are good - I've learned that a bad ground is the biggest culprit for electrical issues in a CJ.
-KJ Newbs / Jersey
1983 lime green CJ7 - 258 with DUI & Weber, Crane cam, 2" lift, MTs w/ BFGs
2010 2-Door, 6-Speed Black JK Sahara - Teraflex 3" Coil Lift with Front Lower and Rear Upper Flex Arms - Bilstein 5100 Shocks -JKS Front Adjustable Track Bar - Teraflex Front Knuckle Gussets - Rock Hard Oil Pan/Engine Skid - Rock Hard Transfer case skid - Rock Hard Evap relocation Kit - Poison Spyder Rocker Knockers - MBRP off-road exhaust - AEV Pintler Wheels - GoodYear MTR/K 35x12.5x17 - Detroit Track Loc Carrier up Front - Yukon 4.88 Gears - Cobra 75 CB with Cool Tech bracket - Die-Tech mirror relocation brackets
KJNewbs is offline
post #4 of 5 Old 01-08-2012, 12:37 PM Thread Starter
usmarine3521
Thank you both for your input. Helped me understand this better
post #5 of 5 Old 01-08-2012, 12:40 PM
CrazyHorse6
1979 CJ7
Originally Posted by KJNewbs View Post
...I've learned that a bad ground is the biggest culprit for electrical issues in a CJ.
Yup!
