Dash clock - JeepForum.com
post #1 of 3 Old 02-28-2014, 07:09 PM Thread Starter
ChrisCarlock
1982 CJ7
Dash clock
I've looked under the dash of my Renegade and I have two random connectors hanging that don't connect to anything on each side of the steering wheel. Are these connectors for the tach and clock options? I don't have a clock or tach.
ChrisCarlock is offline
post #2 of 3 Old 02-28-2014, 08:28 PM
SouthernGypsy
De Oppresso Liber
SouthernGypsy's Avatar
Could also be for the optional fog lamp switch and cigarette lighter.
People would probably need to see a picture of the connectors in question to be able to answer for certain.
~ SouthernGypsy's Jeeps ~
2004 Jeep TJ Rubicon 4.0L/Automatic
1983 Jeep CJ-7 Limited 4.2L/5 Speed
SouthernGypsy is offline
post #3 of 3 Old 03-04-2014, 12:40 PM
wm69
Tach was wired inline, so if you don't have a tach, you should have a red wire with white tracer with a ramdom plug in the middle of it. If equipped with tach, one end of plug went into the tach, and a wire coming out of the tach went into the other plug.
Clock wire plugged into the fuse box. There were lights on both gauges, but not sure how they hooked up.
Can you take pics of the connectors?
wm69 is online now
