Danna 44 swap - JeepForum.com
post #1 of 8 Old 04-14-2013, 06:28 PM Thread Starter
driver007
1981 CJ5
Danna 44 swap
Will a danna 44 from a 75 cj5 fit a 1981 cj5. Would the perchs be narrower? I have a chance to pick up a 75 cj5 and would only buy it if the rear end would work in my 81 cj5.
driver007 is offline
post #2 of 8 Old 04-14-2013, 10:11 PM
RamblingCJ
The spring perches are on the axle, unless someone removed them. You're going to need to get new unbolts and can use the spring plates from the axle you're pulling. Biggest concern is if the gear ratio matches your front axle
RamblingCJ is offline
post #3 of 8 Old 04-14-2013, 11:38 PM
jp360cj
1977 CJ7
Cut and re-weld the spring perches on the rear. The front is a bolt in swap, and you damn swap your disc brake stuff over
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #4 of 8 Old 04-15-2013, 07:47 AM
CSP
Spring perch distance is different, so as said, remove them from their current position and move outward.
CSP is offline
post #5 of 8 Old 04-15-2013, 11:03 AM
dg6772
This is fairly easy to do and when I did mine I bought new perches. They were only about 25 bucks. Not worth trying to save old saves much time.
Dave in Muskegon
dg6772 is offline
post #6 of 8 Old 04-15-2013, 10:41 PM Thread Starter
driver007
1981 CJ5
Right on men thanks. I am not sure if I will go for the parts jeep or not. What year cj5 had the flanged 44
post #7 of 8 Old 04-15-2013, 10:44 PM
dg6772
I think pre-70.
Dave in Muskegon
dg6772 is offline
post #8 of 8 Old 04-16-2013, 07:30 AM
CSP
Flanged Dana 44 is mid-70 through '75 and then the mid-86 CJs had the Dana 44.
Pre-70 is a two-piece axleshaft, not flanged.
CSP is offline
