Danas to 35s? - Page 2 - JeepForum.com
post #16 of 17 Old 03-07-2013, 06:01 AM
ColdSteel85
1982 CJ7
Originally Posted by BagusJeep View Post
T5 box probably has:
4.03:1, 2.37:1, 1:50:1, 1.00:1, .86:1, Rev 3.76:1
A Dana 44 could have a number of ratios from the factory. You could crawl under to read the tag on the diff, raise the wheels and rotate the driveshaft or take off the cover and count teeth.
Like Bagus said you can jack up the rear and spin tire and calculate tire rotation compared to drive shaft rotation. 1 tire rotation will equal xxx amount of drive shaft rotations giving you you ring and pinion ratio. Ex.... 1 tire rotation equals aprox 2 3/4 rotations of drive shaft you likely have 2.72 gears. Good luck!
ColdSteel85 is offline
post #17 of 17 Old 03-07-2013, 11:02 AM
Davis77Cj
1977 CJ7
just a side note, most t-5 transmissions are blown by not re-gearing the diffs when larger tires are installed. not to bash the trans but it does have it's flaws in the way of strength, so keep that in mind when going bigger and considering running w/o a re-gear.
Only in America do you have the God given right to be loudly opinionated about something that you are completly ignorant of.
Davis77Cj is offline
dana , gear ratio , tire
