Dana 44 strength - JeepForum.com
post #1 of 14 Old 05-31-2013, 11:34 AM Thread Starter
aufan
Dana 44 strength
Ive bent the tubing on my stock rear Dana 44. I pulled one to replace it from a rolling scout 2 frame that I have. Just curious if there were any difference in the tubes on this one other than length? Is it any stronger? I am gonna have a shop truss this one.
aufan is offline
post #2 of 14 Old 05-31-2013, 11:54 AM
CSP
Is the diameter the same? Every Scout D44 I've come across uses the smaller 2-5/8" OD tube (same size as a Dana 30) vs. 2-3/4" on most other D44s.
CSP is offline
post #3 of 14 Old 06-01-2013, 03:00 PM
only in a jeep cj
On your bent 86 axle, would you be Intrested in selling an axle shaft out of it provided its not bent too and spins without wobble ? I think I need the drivers side. Ill check
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is online now
post #4 of 14 Old 06-01-2013, 03:01 PM Thread Starter
aufan
driver side axle shaft is bent too i dont think the passenger side is bent
aufan is offline
post #5 of 14 Old 06-01-2013, 03:20 PM
CSP
Is there anywhere in your area that can straighten the tubes? We have a couple of shops in the Denver area who do that regularly. Check for a automotive frame shop.
CSP is offline
post #6 of 14 Old 06-02-2013, 08:26 PM Thread Starter
aufan
Yea I thought about that..but wouldn't the diff still have to be removed?
aufan is offline
post #7 of 14 Old 06-02-2013, 09:00 PM
CSP
The guy that I use doesn't remove the tubes from the diff, if that's what you mean. I've seen pictures from Currie and Dynatrac straightening tubes and they leave them in place as well.
CSP is offline
post #8 of 14 Old 06-02-2013, 11:07 PM
foggybottombob
Who can straighten tubes in Denver?
foggybottombob is offline
post #9 of 14 Old 06-03-2013, 01:24 PM
CSP
Josh @ Crawlertech does it all the time. He has all kinds of fixtures he uses for different axles. I watched him take a Ford 8.8 that was bent like a pretzel (slight exagerration) and straighten it out in about 30 minutes. He's a perfectionist.
CSP is offline
post #10 of 14 Old 06-03-2013, 04:23 PM
foggybottombob
I had crawlertech recommended for axles over on the colorado 4x4 site so he must be the place to go.
post #11 of 14 Old 06-03-2013, 06:11 PM Thread Starter
aufan
I dont see how rebending an axle tube would ever be as strong as it was before it was bent .
aufan is offline
post #12 of 14 Old 06-03-2013, 06:44 PM
foggybottombob
One way would be if you trussed it after you straightened it. Otherwise the difference in strength would be very small.
post #13 of 14 Old 06-03-2013, 07:54 PM
BlueRubiconrich
what are you doing to bend your 86Dana 44? I have not bent mine?
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #14 of 14 Old 06-04-2013, 02:42 PM Thread Starter
aufan
I went a couple weeks back to an offroad park here in TN that had alot of steap hills and rock ledges. I have Yukon ZIP lokcers on both front and rear axles. Did quite a bit of bouncing. I was hanging with 2 other JK's with at least $15,000-$20,000 in mods each. . Anyways I went ahead and pulled the D44 outta the scout and having shop truss it for me. should be up and running by next weekend.
aufan is offline
