dana 44 rebuilt kit - JeepForum.com
post #1 of 6 Old 08-26-2004, 09:28 AM Thread Starter
rapha
dana 44 rebuilt kit
hello ,
on my 1975 cj6 , i have a dana 44 3.73 ratio.
i'm currently rebuilding it and placing a locker....
stock the shim's differential were inside of the bearings ,
but in the rebuild kit it seems the shims are to place outside of the bearings ...
what's the difference ... is there any risk of using those ...
any advice ?
thank's .
91 laredo XJ , 4 inchs lift , rancho ,rear hitch , dyno-max ,
butan converted 4.0 HO
new project 75 CJ6 v8
rapha is offline
post #2 of 6 Old 08-26-2004, 01:03 PM
80cj
80cj's Avatar
1980 CJ5
Dana 44 shims go between the bearing cone and case. Whose rebuild kit are you using?
80cj is offline
post #3 of 6 Old 08-27-2004, 01:28 AM Thread Starter
rapha
i bought it from 4wd, the brand is Motive gear.
but the stock shims were before the bearing ?!!
wich make the rebuilding more difficult....
rapha is offline
post #4 of 6 Old 08-27-2004, 01:38 AM
CSP
Dana 44 shims are supposed to go on before the bearings. Keep it that way no matter the difficulty. I have a set of bearings which I honed out the inner diameter so that I could slide them on and off without a press to get the setup correct. Once my backlash, preload, and gear pattern are correct I press on new bearings.
CSP is offline
post #5 of 6 Old 08-27-2004, 03:10 AM Thread Starter
rapha
thank's
did you took old bearings to do so , or new ones...
i have a pair of old ones i could hone as well...
What is the risk of using external shims?
rapha is offline
post #6 of 6 Old 08-27-2004, 07:37 AM
fuzz401
1978 CJ7
I dont think the shims out side the bearing will stay in place right -keep them under the bearing -this is how all dana rears are to i think
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
Rebuilt Dana 20 Wrong? Hybrid Jeep Jeep CJ Forum 2 04-18-2009 04:56 PM
Those of you that have rebuilt a CJ Dana 30 please assist me! CJman77 Jeep CJ Forum 17 03-30-2009 07:26 AM
Is it a rebuilt 258 CJunk Jeep CJ Forum 8 03-01-2009 04:31 PM
new or rebuilt mc my77cj5levi Jeep CJ Forum 2 12-29-2005 08:45 AM
Rebuilt dana 18 still making noise wild1_robertson Jeep CJ Forum 1 08-29-2004 02:39 PM
