Dana 44 Rear Disk Brakes - JeepForum.com
post #1 of 23 Old 01-02-2007, 08:41 PM Thread Starter
S10
I have a 86 cj7 it has a dana 44 back rear.I was wondering if anyone has done a rear disk brake conversion on one and what they needed?
S10 is offline
post #2 of 23 Old 01-02-2007, 11:19 PM
only in a jeep cj
If you have the late 86 CJ Dana 44, your outer ends of the axle housing are the same as the Model 20. Same drums, same brake shoes and hardware , but the backing plate is slightly different. It looks the same and has the same bolt pattern, but has a larger hole in the center for the axle/bearing to go through due to the one peice axles (bearing faces different way compared to the model 20).
So if I was doing a rear disk set up (and I might), I would research it and treat it as a model 20.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #3 of 23 Old 01-03-2007, 04:41 AM
CJ51973
CJ51973's Avatar
www.binderboard.org has a write up on this. The IH guys have some good info. BillUSN-1 (see the fuel injection sticky on the top of this forum) did the write up and I'm sure he would be happy to answer any questions.
Anything is possible if you don't know what you are talking about.
CJ51973 is offline
post #4 of 23 Old 01-03-2007, 07:39 AM Thread Starter
S10
the link you posted dose not work.... http://www.binderboard.org/
S10 is offline
post #5 of 23 Old 01-03-2007, 09:21 AM
mxg342
mxg342's Avatar
http://www.binderbulletin.org/
'84 CJ-7 Junkyard TBI 360/T18/D300, 4" 4WDH Lift, D44 front with ARB and HS/D44 Rear w/ Detroit, 4.56s, 36" Iroks, TFI, TJ flares, Homemade rocker guards and bumpers with swing out, Optima Yellow Top, M8000, York OBA, 6pt cage
"when you're up to your *** in alligators, it is hard to remember that your original intention is to drain the swamp"
mxg342 is offline
post #6 of 23 Old 01-04-2007, 02:06 AM
Bill USN-1
Just do a search with my username. Bill usn-1 on www.binderbulletin.org
I'm the same guy everywhere!! No name changes to hide!!
I also have the info posted on www.justih.org
There are also writeups for things like a GM hydroboost brake conversion, OBA, OBW, EFI, and others...
FI Mod
Bill at Hamiltonfuelinjectiondotcom
Bill USN-1 is offline
post #7 of 23 Old 01-04-2007, 11:16 AM Thread Starter
S10
thanks for the help
S10 is offline
post #8 of 23 Old 01-05-2007, 08:19 AM Thread Starter
S10
I could not find any info on doing a rear disc brake setup on a dana 44.dose anyone no what parts I need to do this?if so I will get the parts I need and figure it out myself.I just need a general idea where to start
S10 is offline
post #9 of 23 Old 01-05-2007, 09:25 AM Thread Starter
S10
in more searching i did I found some info on mounting brakits that get welded to the rear that speed way sells.but still need to no what rotors and such to use.or is there a better way of doing it
S10 is offline
post #10 of 23 Old 01-06-2007, 04:03 AM
Bill USN-1
You seem to be a little search challenged so here's a direct link.
As i said it's a complete write up with links to various other upgrades.
This is NOT a bolt on conversion.
If that's what you want then don't even click on the link.
There used to be a warn or TSM kit that was a little bit more bolt on friendly but one required a FF axle kit for the D44 before you could install the brake kit!!
Ended up being about $1200.
I would opt for an exploder 8.8 with disc before doing that!!
rear disc for 44
FI Mod
post #11 of 23 Old 01-06-2007, 04:28 AM
jeepskate
There's been several ways to skin this cat over the years and I *know* all of this info is on the web and has been so for at least 8-10 years now. One combo uses Warn's caliper brackets with CJ rotors. The TSM kit is around $400 IIRC...it doesn't include every little piece, but tells you where to source the off-the-shelf stuff...they use a blank Chevy rotor that they drill to your requested bolt pattern. There's several complete kits like SSBC for double to triple that amount. There's a guy on Ebay selling setups with the redrilled 6-bolt rotor like Bill has. You've gotta poke around on some of the sites that have been around a long time like off-road.com, pirate4x4.com and search...you'll find this stuff once you're looking in the right places.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #12 of 23 Old 01-06-2007, 09:41 PM
Z-PDX
Stainless Steel brakes has a GREAT conversion kit for this. I have this on mine. No idea how much it costs retail, but it is a great kit.
The other idea, as mentioned, is the Warn caliper brackets which use the S-10 rotors, these are a nice low-buck way to go and I highly recommend it. They work with Ford rotors from their D44 equiped trucks. The regular 5 on 5.5 ones. I would call over there and ask for Matt in customer service. He can square you away.
-Z
Z-PDX is offline
post #13 of 23 Old 01-07-2007, 08:06 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I've been thinking about doing a disk conversion on my CJ5's rear D44 later on this Winter. I thought I'd try CJ disks (the 1 1/8" thick ones), El Dorado Calipers (with parking brake cable hookup) and some homemade 3/8" thick brackets. If I get around to doing it this winter, I'll be sure to do a writeup and post part numbers..etc.
BESRK is offline
post #14 of 23 Old 01-07-2007, 08:14 PM Thread Starter
S10
rear disc for 44
nice write up.thats what I was looking for.thanks agian
S10 is offline
post #15 of 23 Old 01-08-2007, 05:10 AM
CJ51973
CJ51973's Avatar
Bill's as handy as a pocket on a shirt.
CJ51973 is offline
86 CJ7 rear Dana 44 wants Disc brakes BlueRubiconrich Jeep CJ Forum 8 11-08-2009 09:50 AM
Rear Disk Brakes CJ7 BooneCJ7 Jeep CJ Forum 1 06-27-2007 10:31 AM
disk brakes on '59 CJ5? bkap Jeep CJ Forum 11 10-15-2006 08:37 PM
Drum to Disk brakes DonQuixote Jeep CJ Forum 16 05-09-2006 02:03 PM
model 20 disk brakes jlynch Jeep CJ Forum 6 01-22-2006 08:51 PM
