Dana 44 Pinon Seal and Nut Torque - JeepForum.com
post #1 of 12 Old 01-10-2009, 06:51 PM Thread Starter
asjordan
I swapped out my yoke on my front dana 44 a couple of months back. I did not replace the seal which I am sure was a mistake, but I guess I learned. The seal is now leaking. I bet it is from the brake cleaner I used a couple of weeks ago to clean everything off to try to find the rear main leak or valve cover leak. I wanted everything cleaned off to see if I fixed it.
Now I have a leaking pinion seal that I need to fix. My question is what do I do to torque everything down correctly. When I replaced the yoke I had a problem getting the torque right. I placed the yoke on and used a new nut. When I torqued it to 150lbs I could not even turn the yoke. I backed it off until I could turn the yoke and drive shaft.
What am I doing wrong? I know that on a D44 there is not a crush nut. Am I going to have to go in a pull the diff cover and re-set everything?
Please advise. Thanks for all you help.
1979 CJ7; Fiberglass Tub; Dana 44 f/r; Detroit Lockers f/r; 4.88's; I-6 w/ Holley Fuel Injection; T-150 w/ Dana 20 Twin Stick; Full Cage; 35x12.5x15 Super Swampers
asjordan is offline
post #2 of 12 Old 01-10-2009, 07:17 PM
dwloop
1976 CJ5
The D44 uses shims to set the pinion bearing pre-load, so no matter how tight you make the pinion nut, it should have the correct pre-load. That is if you did not remove the pinion bearings and change shims. Either something is binding, or the pre-load was not set correctly in the first place.
Is the new yoke binding against the seal because of a different dust seal maybe?
Dave
dwloop is offline
post #3 of 12 Old 01-10-2009, 07:50 PM
foggybottombob
Dwloop is right. The torque on the nut should not affect how hard it is to turn the yoke. And the problem is either not enough preload shims or the yoke is rubbing something like he said. I don't know what else could cause that.
foggybottombob is offline
post #4 of 12 Old 01-10-2009, 08:01 PM Thread Starter
asjordan
Could it be possible that when I pulled the old yoke that some of the shims came out with it (ie. stuck to it) and I did not know it or see them? If so, how do I know how many shims to replace because the old yoke is long gone.
asjordan is offline
post #5 of 12 Old 01-10-2009, 08:06 PM
Rollbar
1984 CJ8
Shouldn't cause they R behind the seal.
<----Click
<---- Click
Rollbar is offline
post #6 of 12 Old 01-10-2009, 08:09 PM Thread Starter
asjordan
That is at least one good thing. Maybe I "ate" the seal up with the carb cleaner and all I will have to do it put in a new seal.
asjordan is offline
post #7 of 12 Old 01-10-2009, 08:12 PM
waynehartwig
www.jeeperman.com
waynehartwig's Avatar
1946 CJ2A
I agree with the other two guys on this... Tightness on the nut shouldn't change it. Since it does, tighten that sucker up and see if hitting the pinion square between the yoke or hitting the yoke sides won't loosen it up a bit.
Also, before you put the new yoke on, make sure you use some assembly lube on the seal/yoke.
No, loosing the shims isn't possible - unless you took the bearing out, too. From outside in you have...
Nut
Yoke
seal
slinger
bearing
shims
As for torque on the nut, I believe spec is 200 ftlbs. I'll also use red loctite on a new nut, as well.
1946 CJ2A Ultra4 Race car, street legal!
waynehartwig is offline
post #8 of 12 Old 01-10-2009, 08:13 PM
Rollbar
1984 CJ8
Though you said you couldn't turn the yoke until U backed it off. Something seems wrong to me.
<----Click
<---- Click
Rollbar is offline
post #9 of 12 Old 01-10-2009, 08:16 PM
Rollbar
1984 CJ8
P.S. Super 300 works well on the outer seal, inner splines as well as the yoke face that sits on the slinger.
<----Click
<---- Click
Rollbar is offline
post #10 of 12 Old 01-10-2009, 08:19 PM
dwloop
1976 CJ5
Not unless you removed the front bearing, the pre-load shims are placed behind the front bearing on the pinion shaft... You would have had to remove the seal to get them out... Even if you had left out the oil slinger (if it has one, and still behind the seal) it would not have affected the pre-load, but may have let the yoke slide back far enough to bind.
Like we said before, if nothing is binding, chances are it was not setup correctly before hand.
HTH
Dave
dwloop is offline
post #11 of 12 Old 01-10-2009, 08:55 PM Thread Starter
asjordan
Thanks for the help. I will hopefully get to take a look at it, but unsure if time will allow. I took it out today for one last trip before an extended all expense paid vacation compliments of the US taxpayers. If I don't look at it before I leave I will when I get back this summer.
asjordan is offline
post #12 of 12 Old 01-10-2009, 08:56 PM
foggybottombob
The preload shims are inside the outer bearing. The fit between the bearing face and a small lip on the pinion shaft.
AMC 20 Pinion Rotation Torque (seal replacement) 243 Jeep CJ Forum 8 10-18-2009 07:55 PM
AMC 20 rear pinion seal, torque value, not again jetamerica Jeep CJ Forum 4 08-15-2009 09:54 PM
Odd seal for Dana 30, can't find the right seal, anyone with experience? musicofman Jeep CJ Forum 1 03-15-2009 10:35 PM
Torque for yoke on Dana 44? mud4me Jeep CJ Forum 4 04-25-2008 07:10 AM
AMC 20 Pinon Seal leak...Whats the fix? JeepinYahoo Jeep CJ Forum 15 07-05-2007 08:39 PM
