Dana 44 help - JeepForum.com
post #1 of 7 Old 02-18-2010, 07:32 PM Thread Starter
gotCLAY
Dana 44 help
I have a dana 44 rear in my 84 cj7. The problem is I need a new outer bearing and seal. I bought it for a junk yard and they welded new perches on it. it is stock width for a cj so It might have been cut down or it is from a 86 cj and the P.O did a S.O.A and thats way the had to put new perches on. When I go to the parts store the parts they are trying to sell me are not the right ones And I cant find any #s on the 44 except 316 on the bottom of the housing. any body have an exploded view of a dana 44 rear or know a way to find out what kind it is or what it came out off?
GOOD LUCK & GOD BLESS
gotCLAY is offline
post #2 of 7 Old 02-18-2010, 07:45 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
If you are looking to replace the bearing and seal, both will have a number on them. Get it and have your parts man cross reference them.
jeepdaddy2000 is offline
post #3 of 7 Old 02-19-2010, 07:37 AM
Happy Joe
Instead of going to checker or autozone, go to Napa , or a bearing and seal dealer give them the numbers from the bearing and race that is on the axle and they will be able to take care of you.
The axle that you have is likely from a late 86 CJ as this is the only stock iron cased large lug pattern D44 axle that is the correct width to match your wide track front. Other clues; it will have single piece flanged axles and the correct 5 on 5 1/2" bolt pattern. If it is significantly wider or narrower than your wide track front, or has link mounts cast into the center section, or an aluminum center section, then it most likely is not from an 86 CJ.
Enjoy!
...a well prepped, well driven, vehicle should do well in any terrain, including the highway.
Carburetors became obsolete during the last century... do what ever it takes to get fuel injection...It makes bigger grins off road.
Happy Joe is offline
post #4 of 7 Old 02-19-2010, 08:24 AM
CSP
Yep the existing bearing and seal will have part numbers on them that can be used for cross reference.
The source vehicle of the axle can be identified via the BOM (bill of materials) number that's on the rear of the passenger side tube just to the right of the diff cover. The picture below shows where to look.
You can look up the number here: Dana Bill of Material Number or google "Dana bill of materials" to come up with a host of sites where your number can be looked up.
CSP is offline
post #5 of 7 Old 02-19-2010, 03:49 PM Thread Starter
gotCLAY
Ok so I found out that it is a 86 rear 44. I pulled it apart today. going to take it with me to napa so I can get the right parts. my next question is what kind of tool do you need to get the bearing cup out of the housing. And how much should it cost to have the ring pressed off so i can change the bearing and seal.
gotCLAY is offline
post #6 of 7 Old 02-19-2010, 04:25 PM
foggybottombob
I'm not sure what you mean by "have the ring pressed off". You originally said "outer bearing and seal". If you take off the bearing caps (be sure to keep their orientation marked so you put them back the same way). Then you can pry the differential out of the housing with a couple of pry bars. Take off the pinion nut and the pinion will almost fall out. Pry out the pinion seal and the outer pinion bearing will be just sitting there in the back of the housing. To change the inner pinion bearing you would have to have that bearing pressed off the pinion. It takes a 10 ton or so press to do that.
Typically a brass drift (rod) is used to drive the bearing races out by hitting the rod against the back of the race (on the lip sticking out from the housing). Just go around the race in a circle and bang it out.
foggybottombob is offline
post #7 of 7 Old 02-19-2010, 04:34 PM Thread Starter
gotCLAY
The axle bearings are whats shot. On the axle shaft from outside in I have a retainer, seal, bearing, then a bearing retainer ring that is pressed on the shaft. then right inside the housing is a bearing cup.
gotCLAY is offline
1985 CJ8 swapping in Dodge 1 ton Dana 44 front and Dana 60 rear?????????? JeepScrambler Jeep CJ Forum 8 05-21-2012 06:30 PM
Dana 30 Narrow - Dana 30 Wide swap T3hRustyWalnut Jeep CJ Forum 12 04-23-2009 08:26 PM
Switch from T176 and Dana 300 to T150 and Dana 20?? Need Advice CJ5Freak Jeep CJ Forum 11 07-26-2008 06:56 AM
Swapping Disc Brakes from 81 Dana 30 to 76 Dana 30 PortlandCJ76 Jeep CJ Forum 2 05-13-2007 04:11 PM
Scout dana 20 vs jeep dana 20 (internal gears) pityocamptes Jeep CJ Forum 3 05-18-2004 11:19 PM
