Dana 44 gear pattern - Page 2 - JeepForum.com
post #16 of 30 Old 08-16-2011, 08:56 PM
80cj
80cj's Avatar
1980 CJ5
Originally Posted by foggybottombob View Post
Are you still there Bob? I think this is too shallow now. What do you think?
Yeah, too shallow now. Add in some shims maybe around .006 -.008 worth. Is that an Eaton locker?
80cj is offline
post #17 of 30 Old 08-16-2011, 09:12 PM
80cj
80cj's Avatar
1980 CJ5
Maybe even .010"
80cj is offline
post #18 of 30 Old 08-16-2011, 09:25 PM Thread Starter
foggybottombob
I had already added 0.005". What do you think about this one?
And yes that is an Eaton E-Locker. I have used that a couple of years now and I like it.
foggybottombob is offline
post #19 of 30 Old 08-16-2011, 10:01 PM
80cj
80cj's Avatar
1980 CJ5
I'd say that looks pretty darned good. What's your backlash set at?
80cj is offline
post #20 of 30 Old 08-16-2011, 10:20 PM
80cj
80cj's Avatar
1980 CJ5
Hmmm. Looking at the pics, I don't know if it's the camera angle but I wonder what would happen if you stuck in another .002 or so if shim. the pattern on some coast teeth looks a trifle shallow. Like I said, I can't decide if it's the camera angle.
80cj is offline
post #21 of 30 Old 08-16-2011, 10:29 PM Thread Starter
foggybottombob
Backlash is at 0.008".
post #22 of 30 Old 08-16-2011, 11:02 PM
bandhmo2
That is much better. I would say you could run that with no problems. As already said it might improve a little with the pinion a little deeper, but not much maybe 0.002" worth. However, if you are sick of playing with it, it should be fine.
bandhmo2 is offline
post #23 of 30 Old 08-16-2011, 11:37 PM Thread Starter
foggybottombob
I'll add another 0.002" tomorrow after work. I'm out of garage land and back in computer land now.
post #24 of 30 Old 08-17-2011, 12:23 AM
80cj
80cj's Avatar
1980 CJ5
I've marked the gearteeth that I think are questionable. The pattern looks high or toward the face. Is it really like that or is it camera wide angle lens distortion? The drive side of the teeth further up look pretty well centered face/flank wise.
80cj is offline
post #25 of 30 Old 08-17-2011, 07:26 AM Thread Starter
foggybottombob
I think it's really that high. And note that is only a 0.010" depth change from the first picture.
post #26 of 30 Old 08-17-2011, 07:34 AM
justanotherjpr
Learning a lot from these pics and commentary..
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #27 of 30 Old 08-24-2011, 09:18 PM Thread Starter
foggybottombob
Well I got done tonight finally. The final pattern wound up being only 0.006" out from where it was in the first set of pictures. So is was not really "way deep" to begin with. I have found that a little bit of shims can make a lot of difference in the way the pattern looks.
I've been busy with other stuff and just finally got back to this tonight.
It took 3 tries to get to where I started on this thread. Then it took 3 more tries to get done. I think this is the quickest I ever got a setup done. Thanks to all.
post #28 of 30 Old 08-25-2011, 12:46 AM
80cj
80cj's Avatar
1980 CJ5
Good to hear you got it all wrapped up. I thought about it the other day but figured you either got sidetracked or completed it and moved on. True what you say about small adjustments making a difference. That's the reason I tend to be conservative when suggesting adjustments but sometimes I am too conservative.
80cj is offline
post #29 of 30 Old 01-08-2012, 08:04 PM
xracer33
if you have a good drive side pattern and a so so pattern on the coast side , is there a way to change just the coast side or do you just run it ???
xracer33 is offline
post #30 of 30 Old 01-08-2012, 08:41 PM
80cj
80cj's Avatar
1980 CJ5
Can you post pics of the drive and coast side?
80cj is offline
Take a look at my D44 gear pattern. Sundowners Jeep CJ Forum 19 03-16-2011 11:56 PM
Dana 44 Gear Pattern Check Tuco Jeep CJ Forum 7 03-13-2011 06:41 PM
? Reading used gear pattern in amc 20 aero mech Jeep CJ Forum 2 03-02-2011 08:46 AM
DANA 20 shift pattern carguy68ssrs Jeep CJ Forum 4 07-22-2009 08:55 AM
Dana 30 Gear Pattern RetiredSERE Jeep CJ Forum 5 03-17-2009 09:09 PM
