#1 | |
Dana 44 front swap
I wnat to up grade my front axle to a dana44
. Can anyone let me know what would be a good donor vehicle to get one out of. I would like it to be a pass side drop to keep from flipping my dana20 tc.
Your ghetto sled is my speed bump! BNB #156 |
#2 |
Cool as Ice...
Really need to know what kind of width you want to target first. FSJ or Chevy D44's are generally the most popular and are available in a variety of widths that run from 61"-up. (To put things in perspective, XJ/YJ/TJ axles are about 60".) Scout D44's will require the most work and represent the least bang for the buck from both a hardware and geometry perspective.
This is how NAXJA Midwest Chapter elected officials like to treat their resident users and former multi-year supporters. <--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum! |
#3 |
I want to keep the width fairly close to that of the dana 30. I believe that it is 51.5" wms to wms. By fairly close I was thinking maybe 53" from wms to wms.
#4 |
I narrowed a waggy front about 3"-4" and ran 2" spacers on the back. I lined it up where the spring perch on the pumkin was lined up with the spring and cut the long side down to match.
Anything is possible if you don't know what you are talking about. |
#5 | |
No FunHaters Allowed!
unless you spend the $$ to get custom axle shafts made you will be hard pressed to narrow a full width D44 that much... I think even the NT FSJ's were a few inches more than what you are wanting...
1985 CJ7 Project Phase One : 5.3L Vortec/4L60E, Moser axles for AMC20, Twin Stick'd Dana300 - Completed Phase Two: Bedliner, Rollcage, Seats, BESRK Rear Bumper w/ tire swing, Soft Top, and a few other goodies - Mostly Complete Phase Three: Waggy 44 front, Scout D44 Rear, 4.56's, ARB's (F/R) SOA with YJ Springs, 35x12.50x15 BFG MT - Not Even Close to beginning Also a mostly rust-free 1970 Scout 800A That I'll get to start working on someday... Quote:
#6 |
I would look for a wide track rear end if you are going that route, otherwise you will be quite a bit wider in the front, and a lot of spacing is no bueno.
_____________________ 01 XJ limited: 2 in BB DD 79 CJ-7: 304 t150 d300 twin sticked more fun parts to come |
#7 |
Cool as Ice...
Yeah, no such thing as a D44 that narrow. You'll have to build it. Select your donor based on sufficient tube on the short side in order to keep the passenger leaf on the tube and not on the housing, but also with a short enough long side to position the pinion where the driveshaft won't hit the oil pan. Then you will only need to shorten the long side and add the perch.
#8 |
#9 | |
I was going to take this route about 10 years ago. I had some money tied up in a CJ NT rear D44 and wanted a front D44 to match. With a bare Waggy housing and all of the cutting figured out, it didn't leave much room for spring perches, shock mounts, etc. It was easier to go wider front and rear than to narrow the front to CJ NT specs or thereabouts. |
#10 | |
85 CJ7 Build in progress, 258 with T-5 and dana 300. Fiberglass tub Raptor lined interior, rustoleum lined the underside. Modified family roll bar from fender mounted rollbar. Full tie ins to the frame soon to come. |
#11 |
that gives almost 5 inches wider than wide tracks, which are 4 inches wider than NT. If you want to keep it stock you will have to move your spring perches outside of your frame rails, or cut the short side about 4 inches, get a new axle shaft or cut and re-spline the current one and it will be very close to WT. One good thing I will say about scout axles is they are still native bolt pattern to jeeps, I would go with a mid 70's NT waggy axle and cut it if I were you.
#12 |
No, outboarding is a must and they are more like 61" WMS. The biggest problem with any 44 swap is figuring out your steering system.
1977 Cj5, 258, T-18, 2.46:1 Dana 20, 2.5" BDS lift, OBA, 38.5's. Chevy 60 frt, 14b Rear, Full hydro, 102"wb, full DOM cage. |
#13 |
That's the truth!! Took me a lot of trial and error and $$$ to get it right.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc... 2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s............... John N |
#14 |
Cool as Ice...
Scouts are not that wide. FSJ NT's (Wagoneer) are 61". You are correct that outboarding is required, as well as other custom work on the Scout axles (knuckle yoke rotation).
#15 | |
The best option is to cut down the long side of a waggy Dana 44 and it'll be roughly the width of a widetrack CJ7 axle. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
