Dana 44 front axle CJ5???? - JeepForum.com
post #1 of 18 Old 01-23-2011, 11:35 PM Thread Starter
wvjeepguy76
1979 CJ5
I have a rare Dana 60 rear that is 60inches wide w/4.56 gears 5x5.5 and need a front axle to match. A dana 44 would be great. I've looked all over the forums without any luck. Any help is greatly appreciated!!!!
Thanks
Matt
wvjeepguy76 is offline
post #2 of 18 Old 01-24-2011, 05:53 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
To match a 60" rear axle, I'd probably look for a Waggy D44 front (about 60"). Swap on small GM/Waggy spindles (pre-76?) and use Ford disks to get the 5x5.5" lug pattern.
BESRK is offline
post #3 of 18 Old 01-24-2011, 06:30 AM
jp360cj
1977 CJ7
^what he said
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #4 of 18 Old 01-24-2011, 07:42 AM
CSP
Waggy is about 62.5" and going to five lug adds another inch. That's a good match for a 60" wide rear axle.
CSP is offline
post #5 of 18 Old 01-24-2011, 09:54 AM Thread Starter
wvjeepguy76
1979 CJ5
Awesome guys!!!!
I have a skid full of axles I've been collecting for years and found a set of scout II axles. I really don't want to break up the set so what year Waggy would be good?? Anyone have a set for sale close to WV?
Thanks
Matt
post #6 of 18 Old 01-24-2011, 10:17 AM
jp360cj
1977 CJ7
74 to 79 waggy axles. Newer axles are driver drop and older axles are closed knuckles. I also believe the older axles are 5 lug dana 30s but not 100% sure
jp360cj is offline
post #7 of 18 Old 01-24-2011, 10:30 AM
foggybottombob
To swap the Waggy axle to 5 on 5.5" you need
1) Chevy small bearing spindles (Chevy K10, K5 or Waggy from 73-76 normally have these but not always)
2) Ford Hubs and Rotors (you can use 1979 F150 as a reference for part numbers). Use the Ford rear seal for the hub. The internal spindle bearing is Timken B-2110.
3) Chevy calipers and caliper brackets. 75 K10 is a good reference for part numbers. You can use a later Chevy version of brake parts (mid 80's) and get bigger pistons in the calipers but all the threads on them will be metric.
4) Any Dana 44 internal lockouts will work. Warn, Ford or Chevy are the easiest to find.
foggybottombob is offline
post #8 of 18 Old 01-24-2011, 10:40 AM
CSP
'74-78 chevy calipers are the same as '74-78 FSJ calipers, so the necessary axle will already have the right parts. Caliper brackets can be different, but the axle will already have brackets which work with the existing, correct calipers.
CSP is offline
post #9 of 18 Old 01-24-2011, 10:41 AM
foggybottombob
If it were me, I would get a Ford front Dana 44 and just cut and reweld the tubes to make it passenger side drop. That is what I am going to do when I get past the next 3 CJ projects. The Ford D44 is high pinion and if you get a 77 F150 D44 it has 1/2" wall DOM tubing in it. The way I see it, if you think you need a D60 in the back why not get the strongest front D44 there is while you are at it.
post #10 of 18 Old 01-24-2011, 10:42 AM
foggybottombob
This is true but I always buy new calipers. I guess it's just me.
post #11 of 18 Old 01-24-2011, 01:21 PM Thread Starter
wvjeepguy76
1979 CJ5
I'll post some pics hopefully tonight of my project. I'm putting 42" Rockers under my 81 CJ5 and need the extra strength obviously. This jeep is mainly for show and light wheeling. I won't be too harsh on it but wanted the strength for tire size. This is being built for my "nice" jeep. I have 8 total lol.
post #12 of 18 Old 01-24-2011, 01:30 PM
CSP
A Dana 44 plus 42" rockers don't play well together. That's more like Dana 60 territory even with just light wheeling.
CSP is offline
post #13 of 18 Old 01-24-2011, 01:45 PM
CJ7-1986
I used a Dana 44 off of a Chevy Blazer 1973-76 and its pass side drop. I have some pics on my profile of it.
CJ7-1986 is offline
post #14 of 18 Old 01-26-2011, 12:24 AM Thread Starter
wvjeepguy76
1979 CJ5
Matt's 1981 CJ5 build
These are pics of the jeep when I bought it. I had to ratchet strap axles under this to load her lol. This thing was filthy after sitting in a barn for 2years.
This is what I plan on putting the Waggy front 44 and the rear 60 under with 42" Rockers. I have lots of work ahead of me!!! I have to get this done by May for the 4X4 Jamboree near Lima, Ohio.
post #15 of 18 Old 01-26-2011, 06:36 AM
jp360cj
1977 CJ7
With 42s I would be shopping for a d60 to cut down. Not sure if you could get (or convert) one with 5 lug
jp360cj is offline
360 , dana 44 , dana 60 , swap
Dana 30 ->ford 9" or Dana 44 Front Axle Swap smoothop Jeep CJ Forum 9 09-18-2011 09:28 AM
86 cj7 front axle dana 44 S10 Jeep CJ Forum 11 07-30-2010 04:08 PM
J10 vs J20 dana 44 front axle?? 78treehugger Jeep CJ Forum 12 03-11-2010 01:18 PM
Best Dana 44 front axle dawgates Jeep CJ Forum 4 08-11-2005 04:44 PM
dana 30 front axle? js2 Jeep CJ Forum 9 10-03-2004 09:45 PM
