Dana 44 factory limited slip - JeepForum.com
post #1 of 17 Old 04-04-2013, 07:05 PM Thread Starter
jco6560
1970 CJ5
My apologies if this has been asked before...Is there any way to identify a factory limited slip on a D44 from a 70 CJ5? Does and 'S' after the gear ratio indicate this? Or can it be tracked from the serial number? Based on the wheel spin test with the rear jacked up, it has a limited slip of some type, but wanted some evidence if its Jeep original (Powr Loc, TracLoc or whatever it was called then) or more likely aftermarket.
thanks
jco6560 is offline
post #2 of 17 Old 04-04-2013, 10:49 PM
jp360cj
1977 CJ7
Best way to tell is to pull the cover. Post a pic on here if you're not sure and someone will help you ID it.
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #3 of 17 Old 04-05-2013, 09:37 AM
BlueRubiconrich
A powerloc has a two piece case ,a trac loc has a once piece case.
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #4 of 17 Old 04-05-2013, 03:34 PM
NExOBLIVISCARIS
1970 CJ5
i always thought i had an open diff in my renegade cause there was nothing there to show it was a limited slip but when we took it out after it exploded on me...clutch packs everywhere. if you have the trac lock it is very difficult to tell. do you think you have one?
Jeepy (G-P) 1970 CJ-5 Renegade I, t86 with warn overdrive with a dana 18 , 4.88 rear end and a auburn pro series limited slip.
NExOBLIVISCARIS is offline
post #5 of 17 Old 04-05-2013, 04:23 PM
foggybottombob
A trac-lok clutch set is only good for about 50K miles. They wear out pretty fast. They really are not a very good limited slip choice for a Jeep. I have seen lots of torn up trac-loks in junkyard trucks.
foggybottombob is offline
post #6 of 17 Old 04-05-2013, 09:50 PM Thread Starter
jco6560
1970 CJ5
Both rear wheels spin when up on stands - so some sort of limited slip is happening. Not saying it actually functions to a high degree. I was trying to avoid removing the cover to see, but that may be the best way to go and get a picture. Someone will probably know what it is.
NExOBLIVISCARIS - how do you like the Auburn limited slip?
I was looking to upgrade the differential but seems like not many options for D44 with trac-loc carrier. I am expecting I can put in an upgrade myself if I don't have to do too much resetting the pinon gear (backlash and all the proper spacing and tolerances?). Working on diffs is pretty new to me, but some options seemed doable and some seemed less so.
thanks
jco6560 is offline
post #7 of 17 Old 04-06-2013, 07:10 AM
lucdog
lucdog's Avatar
1980 CJ5
I would ditch the trac lock, and put in a Detroit tru-trac.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #8 of 17 Old 04-07-2013, 08:41 AM
NExOBLIVISCARIS
1970 CJ5
thanks
Welp I haven't finish putting it in. Dana 44 has pros and cons to putting it in. Between me with work and my buddy having college and putting a Ford 302 he and his father built in a 1970 merc 280c. And having to order a part every now and then its taking a while. Just waiting on a carrier bearing to come in due to gumming up the case with a puller. But after that I just have to shim the side lash and back lash then we are done... then I will post on how it is
post #9 of 17 Old 04-09-2013, 02:20 PM Thread Starter
jco6560
1970 CJ5
Does anyone know when Jeep swtich from PowerLock to Trac-Loc? What would have been factory option in 1970?
jco6560 is offline
post #10 of 17 Old 04-09-2013, 06:13 PM
chromegrille
1947 CJ2A
depends on what rear axle you got from the factory...
somewhere in 1970 is the serial number break for the 2 piece D44 tapered axle and the 1 piece D44 flanged axle
tapered axles have 19 splines = powerloc
flanged axles have 30 splines = trac lock
in a nutshell..........
chromegrille is offline
post #11 of 17 Old 04-09-2013, 06:39 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Both diffs were a factory option.
The trac lok is a hand grenade disguised as a diff. I wouldn't use one for a boat anchor.
The Powr Lok is an excellent unit.
there are also a number of other traction units available.
The switch from 19 to 30 splines was in 70 and is easy to recognize.
Tapered axles use 19
Flanged axles used 30
jeepdaddy2000 is offline
post #12 of 17 Old 04-09-2013, 09:10 PM Thread Starter
jco6560
1970 CJ5
Thanks, I am learning a lot (both about D44 axles in general and specifically what what is under the 1970 CJ). Its got a flanged D44 which is nice b/c of the one piece shaft, but that means the limited slip is the undesireable trac-lock (assuming its factory and not something aftermarket). Correct?
Unfortunately, from what I understand, the trac-lock carrier actually makes this more of a hassle to upgrade than just an open diff? Any suggestions on a good limited slip (Auburn, Truetrac, or retrofitting a Power-Loc?). Or is it not really going to matter since I will probably have to remove the carrier anyway? No way I can afford an ARB and keeping it very modest in terms of modification. Daily driver with just above stock capability off-road (4.88 gears and 31 or 32s).
jco6560 is offline
post #13 of 17 Old 04-09-2013, 10:22 PM
jeepdaddy2000
1971 CJ5
Tru trac or Powr Lok. Either will require installing carrier bearings and re-adjusting the back lash.
Powr lok's were available in both 19 and 30 splines. They are rebuildable and are very strong.
http://www.ebay.com/itm/DANA-44-POWE...7a3fda&vxp=mtr
Insure you get the right carrier. There is a break depending on your gear ratio.
post #14 of 17 Old 04-11-2013, 10:14 AM
NExOBLIVISCARIS
1970 CJ5
track lok was also a standard part on the renegade 1's fyi. i had track lok and i sheared the carrier in half
post #15 of 17 Old 04-11-2013, 01:12 PM
duffer
1955 CJ3B
2x PowrLoc one of the best limited slips ever and easy to up the bias.
1955 CJ 3B, 381cid sbc (441cid all aluminum sbc coming soon), AGE M22W, Teralows, Warn OD, OBA, Premier Power welder, Warn 8274
1968 CJ 5, factory 225" w/ headers/450 cfm Holley, T86AA, Belleview winch, Warn OD
2012 Wrangler Rubicon Unlimited, Warn 9.5 xp-s winch
duffer is offline
dana 44 , limited slip differential
