Dana 44 crush sleeve? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Dana 44 crush sleeve?
Offset Tie Rod Kit From RuffStuff!The Original 3/8" Ruffstuff Diff Cover!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 02-24-2014, 01:16 PM   #1
jayzcj5
1978 CJ5
Hey JF,
I'm about to rebuild my D44 wide trac I just got out of a 86 CJ7. I'm ordering parts and I'm seeing some differences in the differential install kits. Some have a crush sleeve listed and some don't? For those who have done this is, is there really a crush sleeve or do you just shim the pinion depth? Thanks in advance for the help!
jayzcj5 is offline   Reply With Quote
Unread 02-24-2014, 01:24 PM   #2
radrick
1974 CJ5
I cant recall ever seeing a crush sleeve in a jeep D-44. Not saying they don,t in every make, but just not jeep. They should have shims to set the preload.
radrick is offline   Reply With Quote
Unread 02-24-2014, 01:54 PM   #3
scooby533
My 86' had shims and no crush sleeve.
scooby533 is offline   Reply With Quote
Unread 02-24-2014, 01:55 PM   #4
jayzcj5
1978 CJ5
Ok this is all good to know before I order these parts. I appreciate the feedback guys!!
Unread 02-24-2014, 04:06 PM   #5
foggybottombob
The only crush sleeve D44 axles I'm aware of are the Isuzu Rodeo and Honda Passport. There are likely more but I doubt the CJ7 Dana 44 uses a crush sleeve. I have not ever seen one though.
foggybottombob is offline   Reply With Quote
Unread 02-24-2014, 04:40 PM   #6
Spieg8
1984 CJ8
Ditto that... my D44 rear came out of an 86 and it doesn't use a crush sleeve.
Spieg8 is offline   Reply With Quote
Unread 02-24-2014, 06:16 PM   #7
CSP
No, the CJ D44 does not use a crush sleeve.
CSP is offline   Reply With Quote
Unread 02-24-2014, 06:52 PM   #8
BlueRubiconrich
a Dana 35 does!
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline   Reply With Quote
Unread 02-24-2014, 08:36 PM   #9
80cj
80cj's Avatar
1980 CJ5
Originally Posted by BlueRubiconrich View Post
a Dana 35 does!
that's porbably because it is an AMC design Dana bought the tooling from AMC. It was known as the AMC 15.
http://www.ask.com/wiki/Dana_35
80cj is offline   Reply With Quote
Unread 02-24-2014, 10:18 PM   #10
jayzcj5
1978 CJ5
Thanks guys! I always turn here for the truth!!
Detroit true-trac, new ring and pinion, and install kit were just ordered. Can't wait to change my narrow trac to wide trac!
Unread 02-24-2014, 10:45 PM   #11
Spieg8
1984 CJ8
Not that it matters, but now I'm curious if it (AMC 15) used a 2 piece axle like the AMC20 did? Who knows, maybe it will be a bit of useful trivia.
Unread 02-25-2014, 07:11 AM   #12
scooby533
Just as a courtesy to the forum, let us know if your pinion has a slinger in the shim stack up when you disassemble. It is useful for the next guy. Mine did, but others did not have it. I was not the first inside my axle assembly either. It did come from a late 1986 model that I had bought as a parts chassis. Original owner rolled the jeep and sold me the rolling chasis for 250$. Got an extra engine, T5, D300, D30 and the Dana 44 out of that deal. As well as a wife asking why? Why the junk Shawn......got to pick the battles and that one was worth it!
Unread 02-25-2014, 10:03 PM   #13
jayzcj5
1978 CJ5
Lol...ok man I will! Probably going to dive in to it next week sometime.
