Dana 44 backlash help - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Dana 44 backlash help
TJ 5.25" Speaker Adapters - NalinMFGTJ, YJ & LJ Drop Down Tail Gate Conversion KitLJ Suspension Systems from Clayton Off Road
Unread 05-16-2014, 07:19 PM   #1
jayzcj5
1978 CJ5
Hey JF,
I'm finishing up my D44 ring and pinion and I need some opinions about the backlash I have. I installed a Richmond ring and pinion which calls for .008 - .012 of backlash. I have .011. I guess I'm ok because I'm within spec but I'm wondering if it's better to be closer to .008 or am I ok where I'm at?
jayzcj5 is offline   Reply With Quote
Unread 05-16-2014, 07:26 PM   #2
78FordF150
1983 CJ7
Did you check it in several places?
If you did and .011 is the biggest reading I wouldn't worry about unless you just wanted to get it tighter.
Measure with a Micrometer
Cutter with an ax
Beat it to fit
Paint it to match
My NP435 install [url]http://www.jeepforum.com/forum/f8/time-tranny-swap-upgrading-np435-1487201/[/url]
78FordF150 is offline   Reply With Quote
Unread 05-16-2014, 07:46 PM   #3
jayzcj5
1978 CJ5
Originally Posted by 78FordF150
Did you check it in several places? If you did and .011 is the biggest reading I wouldn't worry about unless you just wanted to get it tighter.
Yes, I checked it in a few places and every time was the same. I just don't know if I should make it tighter or let it be?
Unread 05-16-2014, 07:52 PM   #4
78FordF150
1983 CJ7
It won't hurt to tighten it up a bit. I always shoot for the low side of the tolerance.
Cutter with an ax
Beat it to fit
Paint it to match
Unread 05-16-2014, 07:59 PM   #5
jayzcj5
1978 CJ5
That's kinda what I thought but then I thought if it's on the tighter side could they prematurely wear? I think I could possibly be splitting hairs but just wanted to see what others who have done this thought?
Unread 05-16-2014, 08:12 PM   #6
80cj
80cj's Avatar
1980 CJ5
What does the pattern look like? Closing up the BL usually moves the pattern toward the toe.
80cj is offline   Reply With Quote
Unread 05-16-2014, 09:04 PM   #7
jayzcj5
1978 CJ5
[QUOTE="80cj"]What does the pattern look like? Closing up the BL usually moves the pattern toward the toe.[/
what u think?
Unread 05-16-2014, 09:10 PM   #8
Truck633
GO ONE MORE!!
Truck633's Avatar
I would leave it at that!!
____________________________________________
You don't need a parachute to skydive... You need a parachute to skydive TWICE!!!
Up here - we go by results, when you preached, people slept. When he flew, people prayed.
Originally Posted by vindicated View Post
It's like dads new mistress. You hate her until you see her boobs.
Originally Posted by ionakana View Post
I bet the new bike riding monkey will pedal a lot faster!
Truck633 is offline   Reply With Quote
Unread 05-16-2014, 09:13 PM   #9
jayzcj5
1978 CJ5
Button it up and run it then? I hear people talk about "wear in" and I guess I'm questioning myself?
Unread 05-16-2014, 09:40 PM   #10
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
X2
I wouldn't touch that.
Don't overthink what your doing. If the picture is good and the backlash is within tolerances, button it up and call it good.
jeepdaddy2000 is offline   Reply With Quote
Unread 05-16-2014, 10:02 PM   #11
foggybottombob
That's a solid pattern.
foggybottombob is offline   Reply With Quote
Unread 05-16-2014, 10:31 PM   #12
jayzcj5
1978 CJ5
Originally Posted by jeepdaddy2000
X2 I wouldn't touch that. Don't overthink what your doing. If the picture is good and the backlash is within tolerances, button it up and call it good.
Ok thanks! I was overthinking a bit cause I want this to be right the first time.
Unread 05-16-2014, 10:31 PM   #13
jayzcj5
1978 CJ5
Thanks for the help fellas!
