Dana 44 axle build up - JeepForum.com
post #1 of 2 Old 03-19-2002, 11:43 AM Thread Starter
jrejle
Post Dana 44 axle build up
I have a 1974 CJ5 w/ Dana 44 30 spline rear axles. I recently replaced the bearing in the passenger side axle and I went with the recomendation in JP Magazine concerning the buildup. I left out the inner seal and am letting the gear oil lube the bearing. Is this a common thing to do? I was hesitant about this and even called a differential shop and they said as long as the outer seal doesnt leak and I have plenty of differential fluid I will be fine. The outer seal isnt leaking and so far no problems but I kept the inner seal just in case. I was curious if anyone has done this and if so did they incounter any problems with this.
Thanks Jim
jrejle is offline
post #2 of 2 Old 03-19-2002, 10:02 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Post
I did the same thing on my 71 about 7 years ago with no problems.
bazinga
jeepdaddy2000 is offline
CJ7 WT Dana 44 & 30 (Re)Build KUJeeper82 Jeep CJ Forum 4 01-17-2010 09:08 PM
Dana 30 build? bluesman423 Jeep CJ Forum 13 05-29-2009 06:01 PM
T176 and Dana 300 Build jcal73 Jeep CJ Forum 15 09-05-2008 07:33 PM
Front Axle Re-build davistroy Jeep CJ Forum 1 02-17-2008 06:43 PM
