Dana 300 Yoke(?) Straps (Front Driveshaft) - JeepForum.com
post #1 of 5 Old 01-06-2006, 12:59 PM Thread Starter
Aphelion79
Aphelion79's Avatar
When I was doing the Twin Shifter for my 300... I noticed that one of the straps that are on the T-Case that hold on the front Driveshaft are loose... its layered with goo and its been as cold as heck out lately... so I haven't really gotten a good look at it... either way I'm going to be changing the fluid in the 300 soon (if I can figure out what kind to put in it, but thats on another thread) and would like to get that fixed at the same time... problem is... from what I could tell, it doesn't look like a bolt or nut...(it actually seemd like a smooth stud, but like I said I haven't cleaned it off very well) ...what should fit on there?
1982 CJ7
Iron Duke "Hurricane" 151 CID 2.5L 4-Cyl
T177 Tranny | Dana 300 T-Case
Dana 30 Front | AMC 20 Rear
Aphelion79 is offline
post #2 of 5 Old 01-06-2006, 02:59 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
It's a bolt. I've seen regular hex head bolts and those 12 point (I think) bolts with small heads. If it's covered in oil/dirt, it probably looks like a stud... but it's a bolt.
BESRK is offline
post #3 of 5 Old 01-06-2006, 10:27 PM Thread Starter
Aphelion79
Aphelion79's Avatar
Ah, hopefuly it is one of those 12 point bolt heads... I was just fearing Torx (And thats something I REALLY don't want to strip!) Just thought I'd make sure, since AMC just decided to randomly strew those Torx pieces of @#%^!! around on Jeeps just to piss off anyone who might try working on it at a later date
1982 CJ7
post #4 of 5 Old 01-07-2006, 06:41 AM
dawgates
1980 CJ7
It's like 5/16 socket or even 1/4".
The bolt head is smaller then the threaded area.
80' CJ7, 360 Howell Injected, 3" single exhaust, NP435 4spd, Dana 300 AA clocking ring, Currie twin stick, Tera-Low 4 -1 kit, Dana 44 front, cut 10" wider to 63", 4.10 gears, ARB, Yukon axles and Super H/D u-joints, Currie Dana 44 rear, cut wider to 60 1/2", 4.10 gears, ARB 35 spline, Currie 35 spline axle shafts, 2 1/2" x 11" Ford drum brakes, CJ-SOA conversion, Tom Woods F & R drive shafts, Warn 9500i winch, 6 point cage, Homemade F&R bumpers and tire carrier, 1" body, Pro Comp supension Kit, 12.5x35x15 BFG's, 15x10 OMF beadlocks, Body armor, OBA.
dawgates is offline
post #5 of 5 Old 01-07-2006, 05:43 PM Thread Starter
Aphelion79
Aphelion79's Avatar
Oh, ... bolt head is smaller than the threaded area, no wonder it looks weird lol... well im gonna go under there tomorrow and I'll let u guys know if anything is FUBAR'ed :P
1982 CJ7
Front Driveshaft Slip-Yoke Play nickdz Jeep CJ Forum 6 11-22-2014 01:55 PM
Dana 20 front CV yoke problems Dislsmoke Jeep CJ Forum 0 05-03-2009 03:01 PM
Dana 300 - Torque specs for front yoke Travisrp Jeep CJ Forum 5 10-03-2008 05:30 PM
Dana 300 yoke to a xj cv shaft? muddyjeepguy85 Jeep CJ Forum 4 09-11-2008 06:35 PM
Dana 20 / CV yoke BIG REED Jeep CJ Forum 3 08-25-2007 01:25 AM
