Dana 300 yoke removel - JeepForum.com
post #1 of 7 Old 04-19-2013, 04:31 PM Thread Starter
mirage100
1976 CJ7
What is the best way to remove a Dana 300 universal joint yoke. Is it a slide hammer ,two jaw puller, 4 jaw puller or a BMFH.
mirage100 is offline
post #2 of 7 Old 04-19-2013, 06:19 PM
82JeepCJ7
1982 CJ7
Once I got the nut off, the yoke slid right off. No tools needed.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #3 of 7 Old 04-19-2013, 06:42 PM
hp_lovecraft
1981 CJ5
As for that nut, I used a huge pipe wrench to hold the yoke, while using a breaker bar to bust the nut loose.
hp_lovecraft is offline
post #4 of 7 Old 04-19-2013, 06:57 PM
82JeepCJ7
1982 CJ7
I just zapped it off with the impact gun. No other tools needed.
post #5 of 7 Old 04-19-2013, 08:21 PM Thread Starter
mirage100
1976 CJ7
I got the nut off but the yoke won't come off. I hit it with BP blaster. I will put a puller on it tomorrow . I bet it is just stuck and will come off. Thank you for all the replies.
post #6 of 7 Old 04-19-2013, 09:29 PM
mrgimble
2015 JK Wrangler
Yep, Use a puller if it is stuck on.
mrgimble is offline
post #7 of 7 Old 04-19-2013, 10:17 PM
78FordF150
1983 CJ7
Smack it a few times on the side with a ballpeen hammer. That should break it loose. Then tap and pull at the same time. It will come off.
Measure with a Micrometer
Cutter with an ax
Beat it to fit
Paint it to match
My NP435 install
78FordF150 is offline
