Dana 300 slips slowly out of gear, help - JeepForum.com
post #1 of 3 Old 08-20-2013, 08:08 PM Thread Starter
Beezer29
Took my Dana 300 out to fix some leaks and when I got it back in and drove the jeep the thing slowly moves from 2h to neutral and starts to make a weird noise when engaging the clutch in first. If I come to a stop and pull it down it resets to 2h. When I took it out, the plastics around the bolt that holds the shifter in place came apart and the bolt is loosely in the two holes. Do I need new springs or a sheath around the bolt to make it more tight? Thanks in advance!!
Beezer29 is offline
post #2 of 3 Old 08-20-2013, 08:20 PM
only in a jeep cj
Yes, you need the two plastic sleeve bushings
http://www.ebay.com/itm/Complete-New...-/190853301071
and I would also see if some one before was in the case.
There are also poppet balls that match notches on the shift rails. These help keep the forks in place (holding it in gear).I would see if one is missing, jammed, or loose in its hole.
Number 5 in this diagram.
http://www.jeep4x4center.com/jeep-tr...-model-300.htm
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #3 of 3 Old 08-20-2013, 09:01 PM Thread Starter
Beezer29
Thanks! I have been looking for that for a while. It's will fix it because it was fine until the plastic came out.
Beezer29 is offline
