dana 300 short or long shaft - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > dana 300 short or long shaft
KrawlOff-Road.com now Carries Iron Rock Off Road!!!!!Toxic Brakes - 3000 PSI Braided Stainless Steel Brake LineFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 05-25-2015, 08:43 PM   #1
dechlin
1980 CJ7
So I'm putting an ax15 in my 1980 cj7 with an adapter from Novak. I have the original Dana 300 which is the short output shaft version, but I also have a spare Dana 300 sitting around. Either way I'm gonaa need new driveshaft. My question is which one should I go with? The long or the short shaft version? Any benefits or advantages to either one? Looking from some input from anyone. Also I plan on going through either one before install
dechlin is offline   Reply With Quote Quick reply to this message
Unread 05-25-2015, 09:15 PM   #2
80cj
80cj's Avatar
1980 CJ5
In a CJ-7 probably no difference. In a CJ-5 it would allow for a slightly longer drive shaft.
80cj is offline   Reply With Quote Quick reply to this message
Unread 05-25-2015, 09:21 PM   #3
only in a jeep cj
I had a short one at one point and remember it was only an inch difference. not enough to matter. PLUS the speedo gears are easy to get on the long ones, not so on the short ones.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline   Reply With Quote Quick reply to this message
