Dana 300 Shifter WASHER? _ NEWBIE HERE - Page 2 - JeepForum.com
post #16 of 23 Old 05-05-2013, 11:50 AM Thread Starter
258
yellow85cj,
I want to thank you to for the posting of the second picture as well.
It seems only fair to spread the wealth.
Good job and THANKS!
258 is offline
post #17 of 23 Old 05-05-2013, 11:57 AM Thread Starter
258
Originally Posted by commadore64 View Post
Thanks for the thread 258... soon to try to put my D300 shifter back together but didn't know how it was supposed to look. PO did a hack job on the shifter years ago and apparently chunked a bunch of parts.
Bought the WASHER at Home Depot and the part # stamped on the washer is "AGB". That's the one you want.
258 is offline
post #18 of 23 Old 05-05-2013, 11:59 AM Thread Starter
258
Originally Posted by Matt1981CJ7 View Post
Now, I know why my shifter still rattles after installing the rubber bushing....I didn't use a washer. DOH!
Matt
Home Depot part # "AGB" which is stamped directly on the washer itself.
258 is offline
post #19 of 23 Old 05-07-2013, 01:26 PM
agear
Originally Posted by keith460 View Post
That's what the washer prevents. Keeps the rubber bushing from sliding upward and applies the down force that's needed to compress it against the link so it won't rattle.
It's amazing what a little piece of hardware, like a washer, can do to prevent noise and looseness of the shifter handle.
Just the weight of the washer holding down the bushing ?
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #20 of 23 Old 05-07-2013, 03:31 PM Thread Starter
258
The shifter shaft gets slightly thicker toward the top which causes the washer to stop moving upward. This is just around the top of the bushing.
Pressure will need to be applied to squeeze the bushing down to lock the shifter in.
258 is offline
post #21 of 23 Old 05-10-2013, 03:24 PM
agear
I see so thats how it works. Another cj fact. Thats what's up .Thanks a lot !
agear is offline
post #22 of 23 Old 05-10-2013, 05:21 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Installed my washer a few days ago.
No more rattling shifter. Woot!!
Thanks gentlemen.
Matt
Matt1981CJ7 is offline
post #23 of 23 Old 05-10-2013, 05:48 PM
agear
Thanks gentlemen.
Matt
Hell yeah
agear is offline
