Dana 300 Shifter WASHER? _ NEWBIE HERE - JeepForum.com
post #1 of 23 Old 05-03-2013, 10:11 PM Thread Starter
258
Can anybody give me the EXACT dimensions of the washer that sits on top of the shifter bushing to stop the rattle noise at high speeds. It's not the T5, it is the Dana 300 shifter.
I found a replacement rubber bushing but I am missing the washer that tends to squeeze the bushing for a tighter fit. I was told a 5/8" washer would work but that one seems to have a lot of play around the inside dimension. (I.D.). Also, its appears to be huge at 1 3/4" wide (O.D.).
Is that the RIGHT one?
Anybody?
* The images show the washer in question. They are off the internet.
258 is offline
post #2 of 23 Old 05-03-2013, 11:23 PM
82JeepCJ7
1982 CJ7
There is supposed to be a bushing and washer up there??
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #3 of 23 Old 05-03-2013, 11:54 PM
mooncruiser
I bought the washers for mine recently from www.4wd.com
93 YJ - 2.5 5spd, NP231 tcase, SYE, CV driveshaft 7"slip spicer, 2.5" Old MAn Emu 36r's all 4 corners, Bilstein 5100's, 4.10 f & r , Posi-Lock front axle, Tuffy boxes, MM winch.
mooncruiser is offline
post #4 of 23 Old 05-04-2013, 05:50 AM
keith460
Jeep. There's Only One
keith460's Avatar
I happen to have that washer in my hand and it is a 1-5/16"OD (1.3125") and 21/32"ID (.65625"). So yes, a 5/8" (.625") washer should be correct.
By the way, that first photo is one that I had taken. You can send me a cash for using it $$$.
1984 CJ-7 Renegade
keith460 is offline
post #5 of 23 Old 05-04-2013, 10:39 AM Thread Starter
258
Your photo? . . . Nice!
Your $$$ should be in the feeling of knowing you have helped a lot of folks posting that, lol . . . good job!
Hey, thanks for those specs.
I just checked the one they sold me and it's the wrong size, way too big. Go figure!
I knew something didn't seem right yet their package was marked wrong.
I will head out today and exchange it for the right one.
It's funny how such a simple item can be the biggest stumbler.
Thanks again for the reply and of course, the posting of that image!
258 is offline
post #6 of 23 Old 05-04-2013, 03:01 PM
agear
that's the correct location for the bushing, in the first picture ?
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #7 of 23 Old 05-04-2013, 09:47 PM
yellow85cj
Yes, in both pics the correct position.
When installing it, it needs to compress, so it helps if you have help pushing the shifter down from the top when re-installing the shifter.
No more rattling shifter.
Second pic is mine.
Currently in pieces - all of them
yellow85cj is offline
post #8 of 23 Old 05-04-2013, 10:23 PM
commadore64
commadore64's Avatar
1980 CJ5
Thanks for the thread 258... soon to try to put my D300 shifter back together but didn't know how it was supposed to look. PO did a hack job on the shifter years ago and apparently chunked a bunch of parts.
1980 CJ-5
My build thread:
Liberalism is the reason why everything else is a problem.
commadore64 is offline
post #9 of 23 Old 05-04-2013, 10:30 PM
firemanjim7
1983 CJ7
Great thread. Since I fixed my exhaust leak I now can hear mine rattling ever so lightly. Now I know what to fix when the time comes.
firemanjim7 is offline
post #10 of 23 Old 05-04-2013, 10:57 PM
agear
Second pic is mine.
Doesn't the bushing just slide up the shifter ?
agear is offline
post #11 of 23 Old 05-04-2013, 11:28 PM
yellow85cj
Yes the bushing slides up the shifter and is stopped by the washer, the washer is stopped by the shoulder on the shifter.
But when you install the shifter, you will need to push down to get the shifter hole to line up with the rod.
BTW the bushing is actually a shock bushing. The original shock bushings were two piece, one for each side of the shock. If you look up shock bushings and the tc bushing in the parts manual, they are the same part number.
So if you need a bushing and only have the one piece hourglass shaped bushing, cutting it in half will work.
The nut in the second pic is not correct. It needs to have a rounded/bowl shape side that fits into the rounded/bowl shape in the shifter.
post #12 of 23 Old 05-05-2013, 12:42 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Now, I know why my shifter still rattles after installing the rubber bushing....I didn't use a washer. DOH!
Matt
Matt1981CJ7 is offline
post #13 of 23 Old 05-05-2013, 03:13 AM
82JeepCJ7
1982 CJ7
In the 31 years we have owned our Jeep... I never knew there was supposed to be anything there. I may have to fabricate something..
post #14 of 23 Old 05-05-2013, 04:30 AM
keith460
keith460's Avatar
That's what the washer prevents. Keeps the rubber bushing from sliding upward and applies the down force that's needed to compress it against the link so it won't rattle.
It's amazing what a little piece of hardware, like a washer, can do to prevent noise and looseness of the shifter handle.
1984 CJ-7 Renegade
keith460 is offline
post #15 of 23 Old 05-05-2013, 08:08 AM
shadoow
Originally Posted by 82jeepcj7
in the 31 years we have owned our jeep... I never knew there was supposed to be anything there. I may have to fabricate something..
x2
shadoow is offline
