Dana 300 Shift Question - JeepForum.com
post #1 of 22 Old 06-22-2013, 11:05 AM Thread Starter
Robbdoe1
1980 CJ5
Hi. I'm trying to figure out how to shift a 1980 CJ5 with a Dana 300 into 4wd. Can anyone tell me the positions? How many? From the seat to the firewall? The shift lever has no label on it.
Thanks for the help.
Robb
Robbdoe1 is offline
post #2 of 22 Old 06-22-2013, 11:20 AM
jp360cj
1977 CJ7
4L
N
2H
4H
front to back
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #3 of 22 Old 06-22-2013, 11:20 AM
jeepwhore
Robb
If you looked at the shift knob it would look like:
4L
N
2H
4H
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #4 of 22 Old 06-22-2013, 11:46 AM Thread Starter
Robbdoe1
1980 CJ5
Thanks for the quick replies. It feels like it only has 2 positions...... Or at least those are the 2 that it goes into as of now. They seem to be the 4H and 2H positions. When I engage 4H the light on the Speedo goes on and says 4 wheel drive engaged.
I have the hubs locked if that matters an I'm also jigging the clutch a lil in first to get her rolling a lil bit as other posts suggested. Any help or ideas would be appreciated
Robb
Robbdoe1 is offline
post #5 of 22 Old 06-22-2013, 11:54 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
With the engine OFF and the transmission in Neutral, the T-Case should shift freely into all modes.
CJ7-Tim is offline
post #6 of 22 Old 06-22-2013, 12:02 PM Thread Starter
Robbdoe1
1980 CJ5
It doesn't. Rut row. Now what?
Robbdoe1 is offline
post #7 of 22 Old 06-22-2013, 12:08 PM
Truck633
GO ONE MORE!!
Truck633's Avatar
If it is tight, lock the hubs, throw it in 1st or 2nd and give it a good rockin.... you may just be a little bound up
____________________________________________
You don't need a parachute to skydive... You need a parachute to skydive TWICE!!!
Up here - we go by results, when you preached, people slept. When he flew, people prayed.
Originally Posted by vindicated View Post
It's like dads new mistress. You hate her until you see her boobs.
Originally Posted by ionakana View Post
I bet the new bike riding monkey will pedal a lot faster!
Truck633 is offline
post #8 of 22 Old 06-22-2013, 12:42 PM Thread Starter
Robbdoe1
1980 CJ5
Still a no go. I clearly have 4H and 2H. I blasted it with some Kroil. I'll let it soak then try again. If I can't get N and 4L is this a transfer case issue? Lots of leaks under this thing at the diff seals.
Robbdoe1 is offline
post #9 of 22 Old 06-22-2013, 12:47 PM
Truck633
GO ONE MORE!!
Truck633's Avatar
nex step crawl under and look. you should have two rods connected by a "saddle" that joins your tcase shift lever, it cams over as you shift up and pulls the levers into their detents. While under (with goggles) have girlfriend shift the entire range and report back!
Truck633 is offline
post #10 of 22 Old 06-22-2013, 01:07 PM Thread Starter
Robbdoe1
1980 CJ5
Success. I see the rods and linkage. I kroiled them up and worked it back and forth while jerking off the clutch. This bad boy was stuck but good. You can tell when it hits 4L cause it lowers down and grabs up.
Only problem now is I lost that nifty lil 4wd indicator on the speedo? Over travel or too much lube? Thanks for all the help so far guys. I appreciate it. I'd be lost without it.
Robb
Robbdoe1 is offline
post #11 of 22 Old 06-22-2013, 01:14 PM
LumpyGrits
Sometimes you need to back up 4-5 feet to take the load off the drive line.
Do your T'case shifting while in a straight line.
2 H to 4H you can shift while moving. Stop or no faster than a VERY slow walk to go to 4LO.
Not uncommon to have to stop and back up a few feet to get the t'case from 4LO to 2H or 4H.
LG
LumpyGrits is online now
post #12 of 22 Old 06-22-2013, 01:18 PM Thread Starter
Robbdoe1
1980 CJ5
Wow so true. I had to back up to get out of 4L. I'm just happy it's working now. That and checking out the frame were all that were keeping me from moving ahead with a restore and both pass the test.
BIG THANKS GUYS.
Robb
Robbdoe1 is offline
post #13 of 22 Old 06-22-2013, 01:58 PM
Truck633
GO ONE MORE!!
Truck633's Avatar
no prob, glad to help!!
Follow the little orange wire on the top of your Tcase and wiggle it around, should lite up your dash. They get pretty gummed up
Truck633 is offline
post #14 of 22 Old 06-22-2013, 07:33 PM
draperjojo
1946 CJ2A
I find it helps to cut the wheel a little, and rock it some.....
draperjojo is offline
post #15 of 22 Old 06-22-2013, 07:41 PM
agear
Maybe its not going into 4l as far as it the shifter and shift rails can and that's why you're not getting the 4wd light while in 4LO possibly hitting the tunnel cover.
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is online now
