Dana 300 rebuild? - JeepForum.com
post #1 of 6 Old 05-06-2005, 02:02 PM Thread Starter
5artist5
5artist5's Avatar
1972 CJ5
Dana 300 rebuild?
I want my dana 300 overhauled. Not sure if I should get the Novak rebuild kit and try it myself or sent it out. I did a partial rebuild of my sm465 when I replaces the output shaft with one fron Novak. Can anyone comment on how difficult dana300 rebuilding is?
5artist5 is offline
post #2 of 6 Old 05-06-2005, 03:13 PM
jeepskate
I'm pretty sure there's some write-ups on the web...at the very least write-ups on installing a 4:1 kit which will also cover the rebuild...google it.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #3 of 6 Old 05-06-2005, 06:07 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I would say that, if you can tinker around in a SM465, you can do the Dana 300. It's not very difficult. You'll need a pair of snap ring pliers, a gear puller and access to a bearing press. Just lay the parts out on a table as you take them apart. HERE'S a link to JB Conversions' Instructions for the Lomax kit. It's pretty good.
BESRK is offline
post #4 of 6 Old 05-07-2005, 06:02 AM
CJ51973
CJ51973's Avatar
Ditto what BERSK said. The first trans,tcase I had ever rebuilt was my 3.15:1 kit in my Dana 20. If you can handle the trans work you'll be fine in the tcase. I sure the Novak kit will have good instructions.
Anything is possible if you don't know what you are talking about.
CJ51973 is offline
post #5 of 6 Old 05-07-2005, 11:00 AM
Cherokeester
Cherokeester's Avatar
1980 CJ7
I did the teralow 4-1 kit myself, took awhile because I wanted to make sure everything was right before I reinstalled it. Basic tools plus a grinder and snap ring pliers as mentioned above are a must. Plan on a solid day or two.
1980 CJ-7 with a AMC 401, RE 4.5" Lift, 4-1 Dana 300, Holley TBI Projection, 35" Goodyear MTR's
2010 Rubicon Unlimited
1997 TJ with various enhancements
Cherokeester is offline
post #6 of 6 Old 05-08-2005, 08:20 AM
cjbilt4me
It's not that difficult to rebuild the 300.Having access to a shop press makes it easier.The rebuild kits vary in price depending on where you buy it($110-$175).Novak has a a good instruction sheet.
85 CJ7,9"HPC/ Detroit,44 spooled,SOA,36 IROCS,Redneck Ram,300/twin stick/Tera Low,MPFI,Premier Welder,Warn 9000I
cjbilt4me is offline
Best dana 300 rebuild kit? Johnyakimo1855 Jeep CJ Forum 1 01-06-2010 03:45 AM
Dana 300 rebuild ego99 Jeep CJ Forum 1 12-24-2008 03:59 PM
dana 44 rebuild gregsteele1979 Jeep CJ Forum 0 09-12-2006 10:39 AM
Dana 20 Rebuild - Help dreski1 Jeep CJ Forum 8 01-23-2006 05:55 AM
