Quantcast Dana 300 installation - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Dana 300 installation
Old 11-30-2006, 09:42 AM   #1
weprint
I am putting the transfer case back into an 81 CJ7 and am having trouble with the shift linkage. I didn't think I moved the shift shafts while I had it out, but it is possible. Presently, one shaft is further in than the other and I am having trouble installing the link with the two clevis pins. Do these shafts move in tandem in all ranges or are there ranges where one shaft is further in than the other? I cannot move either shaft in or out so I assume I must take off the bottom cover and move the shift forks to get the clevis pins in. Is this correct? Any help is appreciated.
weprint is offline   Reply With Quote
Old 11-30-2006, 12:15 PM   #2
Aphelion79
Yeah when you're in 2WD the left rod is further in than the right side. (Drivers / Passengers)
The way it works is like this:
The Driver's side rod controls the rear wheels....
in = high gear
middle = neutral
out = low gear
The passenger's side rod controls the front wheels...
in = high gear
middle = neutral
out = low gear
So in 2WD the left side is in, while the right side is in the "middle" position...
1982 CJ7
Iron Duke "Hurricane" 151 CID 2.5L 4-Cyl
T177 Tranny | Dana 300 T-Case
Dana 30 Front | AMC 20 Rear
Aphelion79 is offline   Reply With Quote
Old 11-30-2006, 08:12 PM   #3
dave_dj1
sometimes if you can't get the shift-shaft to move freely, you can rotate the rear yoke a little and it will usualy let you move the shaft.
dave_dj1 is offline   Reply With Quote
Glock Forum
