Dana 300 install tips HELP - JeepForum.com
post #1 of 13 Old 09-10-2012, 12:22 PM Thread Starter
TxJeeper20
1982 CJ5
Ok So I replaced the input oil shaft on the front of my d300 now im struggling to get it installed. Any tips or tools to put it in? lifting it seems kinda off the wall haha
Its way easier to pull it than put it back in
Victory Loves Preparation
1982 CJ-5 350TBI/AX-15
1989 Porsche 928 S4
2003 Honda VTX 1300R
2005 Infiniti G35
TxJeeper20 is offline
post #2 of 13 Old 09-10-2012, 12:37 PM
foggybottombob
What is an input oil shaft? Here is a set of instructions on how to take a D300 apart and put it back together.
http://www.jbconversions.com/pdf/2307.pdf
foggybottombob is offline
post #3 of 13 Old 09-10-2012, 01:40 PM
mvbrady
A helping hand can make all the difference....if you have some studs(threaded rod) available to thread into the tail
to use as guides ...then a floor jack to get it close...then shove it,curse it,pull it,kick it on.
good luck.
mvbrady is offline
post #4 of 13 Old 09-10-2012, 01:47 PM
twoleos617
ive always rolled it onto my chest and bench pressed that sucker. takes a few tries cause that sucker is HEEEEEAVY!
there are tranny jacks that you can buy but they're pricey. or there are adapters for trannys and will hook up to a standard floor jack.
Torque is the measure of force that gets the cap off your beer.
Mike D.
twoleos617 is offline
post #5 of 13 Old 09-10-2012, 04:05 PM
foggybottombob
I used my neighbor's tranny jack to put my D300 back on my transmission.
post #6 of 13 Old 09-10-2012, 05:04 PM
agear
I have a 2inch suspension and 1 inch body lift and I'm 5'10". I'm able to sit indian style-hunched over a little bit- and just put it on there.
In any event: the input shaft of the transfer case has a bore with internal splines. Start by sticking the bore over the output shaft of the transmission and then push it on to the 2 studs.
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #7 of 13 Old 09-11-2012, 07:17 AM Thread Starter
TxJeeper20
1982 CJ5
good luck.
Yea I have the floor jack adaptor, just the plate no other parts I needed a way to get the thing to move when we get it in position I like that idea alot
and i was amazed why my leak just got bad all of a sudden haha my seal was dry rotted. Its such a PITA just for one little seal
1989 Porsche 928 S4
2005 Infiniti G35
post #8 of 13 Old 09-11-2012, 07:20 AM
twoleos617
did you change the fluid while its out??!!
Mike D.
post #9 of 13 Old 09-11-2012, 09:28 AM Thread Starter
TxJeeper20
1982 CJ5
I drained it to reduce weight and didnt want it spilling everywhere haha reduce weight..........
1989 Porsche 928 S4
2005 Infiniti G35
post #10 of 13 Old 09-11-2012, 10:52 AM
titomars
1981 CJ7
I take out the the left side upper pan bolt and I mounted a block of wood cut to fit the angle and bolted to the case through that bolt hole. then i just use my floor jack with a tie down around the case to hold it. Not the greatest way to do it but it worked for me coming out and going back in.
1981 Jeep CJ7 4.0 HO, AX-15, D300, D30, D44, SOA
1977 Chevrolet C/10 step side 454 TH400 3.73 posi
titomars is offline
post #11 of 13 Old 09-11-2012, 12:19 PM
twoleos617
nuthin funny about that! ive spilt a freakin quart on my chest before. threw the shirt away and had to scrub like hell to get the stench off me!
your a smart man!
Mike D.
post #12 of 13 Old 09-11-2012, 12:49 PM
titomars
1981 CJ7
your a smart man!
Been there, done that! more than once.
titomars is offline
post #13 of 13 Old 09-11-2012, 01:09 PM
Splinter
1980 CJ5
Wow , good instructions. And the guy didn't even get his hands dirty. LOL
Splinter is offline
Any tips on rotating inner Dana 44 knuckles? Gasman303 Jeep CJ Forum 16 08-10-2011 08:40 AM
moser axles for amc 20 install tips baja67 Jeep CJ Forum 1 07-07-2010 12:31 AM
Any tips on removing the Dana 300? foggybottombob Jeep CJ Forum 13 12-20-2008 07:49 PM
tips on trans install joconnor66 Jeep CJ Forum 1 06-09-2003 11:46 AM
clutch install tips?? KG4PAM Jeep CJ Forum 3 04-14-2002 10:07 PM
