Dana 300 Dana 20 CV Driveshaft Links - JeepForum.com
post #1 of 12 Old 11-04-2009, 02:48 PM Thread Starter
JeepnBlake
Attention: This thread was created by me so that there is a place to learn about what parts you need to run a Double Cardan driveshaft. Double Cardan and CV are not the same thing.
This is a great thread about double cardan information:
http://www.jeepforum.com/forum/f9/wh...nt-one-854790/
Dana 300
Dana/Spicer Part Number: PN 2-4-4341 (for 1310)
Links To Buy:
Dennys Driveshafts > CV Yoke Dana 300 Transfer Case 1310 Series 26 Spline
Threads:
http://www.jeepforum.com/forum/f8/ad...-joint-601687/
http://www.jeepforum.com/forum/f8/do...-shaft-756179/
http://www.jeepforum.com/forum/f8/da...-shaft-604943/
Dana 20
Dana/Spicer Part Number: PN 2-4-4061X (for 1310)
Links To Buy:
(P/N 716298) Dana 20 1310 CV Yoke | Engine & Transmission Conversion Adapters - Advance Adapters 10 Spline Version
http://www.dennysdriveshaft.com/p430...26_spline.html 26 Spline Version
Make your own Double Cardan:
http://www.jeepforum.com/forum/f8/ma...-shaft-751383/
Good Sources for Double Cardan driveshafts:
Wrangler TJ Front (1310)
Cherokee XJ Front (1310)
Grand Cherokee ZJ Front 93-95 (1310)
Sticky Please?
-Blake-
Build Thread:
Dad's Build Thread:
OEM Fog Light Connectors, Conversions, and Extension Info:
JeepnBlake is offline
post #2 of 12 Old 06-30-2010, 06:17 PM
postaldave
let me be the first to say thanks! doing a 300 install and your post was awesome!
maybe add some more info about the 300. like 4:1 upgrades, outshaft upgrades.
1976 FJ40 aka Yoda Monster
1996 Jeep XJ
Originally Posted by xdgt03 View Post
I removed mine. It is against federal law but so is being an illegal immigrant so...
postaldave is offline
post #3 of 12 Old 06-30-2010, 07:27 PM Thread Starter
JeepnBlake
That's a good Idea, and thank you.
Edit: Info on gearing added.
-Blake-
Build Thread:
Dad's Build Thread:
post #4 of 12 Old 07-01-2010, 08:37 AM
CSP
Is that part number for the Dana 20 CV yoke a 10 spline or 26 spline? The 26 spline version can use the same yoke as the Dana 300.
There are two spline counts available on the Dana 20.
CSP is offline
post #5 of 12 Old 07-01-2010, 10:00 AM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
Please change it to call the yoke a double-cardan and not a CV so that people learn the correct terminology. A Constant Velocity joint is something different. This is just like calling HP gears and axles "reverse rotation" (also wrong). Vendors calling it a CV yoke is just laziness and continues to perpetuate the problem.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
post #6 of 12 Old 07-01-2010, 03:16 PM
postaldave
if you are going to make an info post be absolutely correct is important. agreed.
i would also add info as to hooking up a dana to a ax15 and other common jeep tranys. i've learned that even though the bolt pattern is correct i still need a clocking ring and maybe a spacer to bolt mine up since the ax15 shaft is too long. i still don't know the correct answer to this.
1996 Jeep XJ
post #7 of 12 Old 07-01-2010, 03:57 PM
PavementPounder
Cool as Ice...
I'd keep it as just yoke information. Make separate threads about low gears for each transfer case or transmission compatibility. That way the threads will be indexable if they are added to the FAQs.
post #8 of 12 Old 07-01-2010, 04:40 PM
kakai81
I know what you mean about the double cardan v. CV info. However, all the auto parts places have them listed as CV. If you only type double cardan here, and a newbie walks into the auto parts store asking for a double cardan, the staff are going to look at him like dumb cows. I know, it happened to me. Hell, when I say i need parts for a CJ7 they ask me what make it is. Lets just try to make sure we know there's a difference and leave the part info the same as it is in the stores.
kakai81 is offline
post #9 of 12 Old 07-01-2010, 07:28 PM Thread Starter
JeepnBlake
That's a very good point as is the one about Double Cardan only thread. Advice taken.
-Blake-
Build Thread:
Dad's Build Thread:
post #10 of 12 Old 07-01-2010, 08:57 PM
postaldave
can you buy a double card at an auto parts store?
1996 Jeep XJ
post #11 of 12 Old 07-02-2010, 09:51 AM
PavementPounder
Cool as Ice...
That's called "planning for failure" and those people should be fixed.
Yes. You can buy just the pieces you need or the entire assembly. The trick is that it won't be connected to a driveshaft if you buy a new one in the store and you'll have to weld it on. This is why most people opt for buying a used DC driveshaft longer than what they need so that they can have the pinion end shortened to suit their purposes and just rebuild the DC that is already on it.
post #12 of 12 Old 07-02-2010, 12:06 PM
kakai81
If you're talking about the parts store people, they all need to be fixed anyway.
kakai81 is offline
1985 CJ8 swapping in Dodge 1 ton Dana 44 front and Dana 60 rear?????????? JeepScrambler Jeep CJ Forum 8 05-21-2012 06:30 PM
Switch from T176 and Dana 300 to T150 and Dana 20?? Need Advice CJ5Freak Jeep CJ Forum 11 07-26-2008 06:56 AM
Swapping Disc Brakes from 81 Dana 30 to 76 Dana 30 PortlandCJ76 Jeep CJ Forum 2 05-13-2007 04:11 PM
Dana 300 Yoke(?) Straps (Front Driveshaft) Aphelion79 Jeep CJ Forum 4 01-07-2006 05:43 PM
Scout dana 20 vs jeep dana 20 (internal gears) pityocamptes Jeep CJ Forum 3 05-18-2004 11:19 PM
