-   -   Dana 300 Dana 20 CV Driveshaft Links (http://www.jeepforum.com/forum/f8/dana-300-dana-20-cv-driveshaft-links-894019/)
JeepnBlake 11-04-2009 02:48 PM
Attention: This thread was created by me so that there is a place to learn about what parts you need to run a Double Cardan driveshaft. Double Cardan and CV are not the same thing.
This is a great thread about double cardan information:
http://www.jeepforum.com/forum/f9/wh...nt-one-854790/
Dana 300
Dana/Spicer Part Number: PN 2-4-4341 (for 1310)
Links To Buy:
Dennys Driveshafts > CV Yoke Dana 300 Transfer Case 1310 Series 26 Spline
Threads:
http://www.jeepforum.com/forum/f8/ad...-joint-601687/
http://www.jeepforum.com/forum/f8/do...-shaft-756179/
http://www.jeepforum.com/forum/f8/da...-shaft-604943/
Dana 20
Dana/Spicer Part Number: PN 2-4-4061X (for 1310)
Links To Buy:
(P/N 716298) Dana 20 1310 CV Yoke | Engine & Transmission Conversion Adapters - Advance Adapters 10 Spline Version
http://www.dennysdriveshaft.com/p430...26_spline.html 26 Spline Version
Make your own Double Cardan:
http://www.jeepforum.com/forum/f8/ma...-shaft-751383/
Good Sources for Double Cardan driveshafts:
Wrangler TJ Front (1310)
Cherokee XJ Front (1310)
Grand Cherokee ZJ Front 93-95 (1310)
Sticky Please?
postaldave 06-30-2010 06:17 PM
let me be the first to say thanks! doing a 300 install and your post was awesome!
maybe add some more info about the 300. like 4:1 upgrades, outshaft upgrades.
JeepnBlake 06-30-2010 07:27 PM
That's a good Idea, and thank you.
Edit: Info on gearing added.
CSP 07-01-2010 08:37 AM
Is that part number for the Dana 20 CV yoke a 10 spline or 26 spline? The 26 spline version can use the same yoke as the Dana 300.
There are two spline counts available on the Dana 20. ;)
PavementPounder 07-01-2010 10:00 AM
Please change it to call the yoke a double-cardan and not a CV so that people learn the correct terminology. A Constant Velocity joint is something different. This is just like calling HP gears and axles "reverse rotation" (also wrong). Vendors calling it a CV yoke is just laziness and continues to perpetuate the problem.
postaldave 07-01-2010 03:16 PM
if you are going to make an info post be absolutely correct is important. agreed.
i would also add info as to hooking up a dana to a ax15 and other common jeep tranys. i've learned that even though the bolt pattern is correct i still need a clocking ring and maybe a spacer to bolt mine up since the ax15 shaft is too long. i still don't know the correct answer to this.
PavementPounder 07-01-2010 03:57 PM
I'd keep it as just yoke information. Make separate threads about low gears for each transfer case or transmission compatibility. That way the threads will be indexable if they are added to the FAQs.
kakai81 07-01-2010 04:40 PM
I know what you mean about the double cardan v. CV info. However, all the auto parts places have them listed as CV. If you only type double cardan here, and a newbie walks into the auto parts store asking for a double cardan, the staff are going to look at him like dumb cows. I know, it happened to me. Hell, when I say i need parts for a CJ7 they ask me what make it is. Lets just try to make sure we know there's a difference and leave the part info the same as it is in the stores.
JeepnBlake 07-01-2010 07:28 PM
That's a very good point as is the one about Double Cardan only thread. Advice taken.
postaldave 07-01-2010 08:57 PM
can you buy a double card at an auto parts store?
PavementPounder 07-02-2010 09:51 AM
That's called "planning for failure" and those people should be fixed. :laugh:
Yes. You can buy just the pieces you need or the entire assembly. The trick is that it won't be connected to a driveshaft if you buy a new one in the store and you'll have to weld it on. This is why most people opt for buying a used DC driveshaft longer than what they need so that they can have the pinion end shortened to suit their purposes and just rebuild the DC that is already on it.
kakai81 07-02-2010 12:06 PM
If you're talking about the parts store people, they all need to be fixed anyway.
The time now is 06:46 AM.
