Quantcast dana 300 clocking ring ut oh - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > dana 300 clocking ring ut oh
RUBICON EXPRESS Lift Kits and Accessories Available at BasSpartan Lockers FREE SHIPPING Excellent PricesFree Shipping on TIRES at KrawlOff-Road
Old 08-27-2006, 07:29 PM   #1
gumby
I have a question...and knowing that we are all mental giants here I thought I would ask. those of you who are not mental giants can stop reading now.
I want to clock my dana 300 and get rid of my transfer case skid plate so that I can have a nice flat sheet of steel under the frame. more clearance not get hung upon rocks etc...
so if I clock it and lose the stock skid plate I also lose the 1 inch skid plate drop that I installed to eliminate the drivetrain noise/vibration. what is the cheap easy fix to this? anyone anyone bueler bueler
1984 CJ-7 offroad special loves to get dirty and play rough. unlike the girls I meet
258 rebuilt with torquer cam/ weber 32/36 carb, HEI ignition ,headers 4 in lift AMC 20 detroit rear locked and trussed / tru trax front 4:56 Gears ,solid axles on 35's
"Two roads diverged in a wood and I - I took the one less traveled by, and that has made all the difference."-
Robert Frost
gumby is offline   Reply With Quote
Old 08-27-2006, 10:14 PM   #2
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
The cheap easy fix is to leave it alone. Everything else you mentioned is gonna cost at least a little money and require some hard work. I would be sure to run a rear CV driveshaft, ditch the 1" TC drop, build a frame work and mounting system for the TC that can be "skinned" with something like 3/16" or 1/4" steel. Not sure what kind of effect clocking will have on TC to body tub clearance.. maybe a 1" body lift would help. Also, if you're already running quite a bit of suspension lift, you'll want to check the front driveshaft ujoints at full droop to make sure they won't bind...
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s..
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote
Old 08-28-2006, 06:04 AM   #3
gumby
running a 4 in suspension lift now clearence is only been and issue once or twice
I mean I am running 35's and lifted 4 in so I clear most anything as long as I don't get to radicial
Robert Frost
Glock Forum
