Dana 300 Clicking when turning hard left - JeepForum.com
post #1 of 5 Old 09-28-2011, 07:30 PM Thread Starter
shull360CJ7
I've recently noticed a few "clicks" coming from what I believe to be my TC when turning hard left. The sound is a very mild version of the grinding noise you get when the TC isn't fully engaged.
The shifter doesn't bind in the floor or anything. I am running an Advance Adapter from TH400 to Dana 300. Had to notch out front of cross member to clear front drive shaft but I drove it for a while before the noise developed.
I'm gonna start by checking fluid although I have no leaks. I definitely want to look into having a custom and much stronger cross member made soon.
Any other thoughts or suggestions?
Thanks,
Brian
'98 Sport, 5 Speed. Green Emerald Metallic. Bestop soft top.
BDS 2" lift, AR steel wheels, 31"x10.5" Goodyears. Stock axles, stock 3.07 gears.
Immigrant from the CJ world...be patient...I can be taught
shull360CJ7 is offline
post #2 of 5 Old 09-28-2011, 07:33 PM
BagusJeep
1981 CJ7
is the suspension flexing to one side when you turn? This could cause some rubbing on the drive shaft.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #3 of 5 Old 09-28-2011, 07:36 PM Thread Starter
shull360CJ7
I don't believe. Superlift springs, not so hot in the flex department.
I don't get much body roll from the Jeep.
post #4 of 5 Old 09-28-2011, 09:58 PM
82JeepCJ7
1982 CJ7
Is this on dirt, or pavement? It is normal for stuff like this to happen on pavement. Check the condition of your front axle U-joints at the knuckles. The sound may be transmitted up the driveline.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #5 of 5 Old 09-29-2011, 04:27 AM Thread Starter
shull360CJ7
Ok. I'll check that. Thanks.
