Dana 300 - JeepForum.com
post #1 of 9 Old 11-30-2011, 09:08 AM Thread Starter
cadesertjp
Dana 300
How do you go about clocking a dana 300 transfer case and is it worth it.
Chris
cadesertjp is offline
post #2 of 9 Old 11-30-2011, 09:23 AM
John N
1981 CJ8
There are several ways to go about this, I used this kit http://www.jbconversions.com/products/dana300/plate.php and their 4:1 kit. I didn't turn mine up flat, just halfway up from stock. "Worth it" just depends on your use, less lift and more clearance. You'll have to modify your skid plate or build a new one to take advantage of this.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #3 of 9 Old 11-30-2011, 09:25 AM Thread Starter
cadesertjp
Thank you John.
post #4 of 9 Old 11-30-2011, 09:31 AM
addicted2dunes
1981 CJ8
Here's a clocking ring for you: http://www.ebay.com/itm/Dana-300-Clo...item2eb992336f
Cameron Gunlock
1981 CJ8 -
http://www.facebook.com/pages/Central-Coast-Krawlers/139075302856004
addicted2dunes is offline
post #5 of 9 Old 11-30-2011, 09:36 AM Thread Starter
cadesertjp
Now I'm confused why does one have a shaft and the other does not.
Chris
post #6 of 9 Old 11-30-2011, 11:06 AM
addicted2dunes
1981 CJ8
JB's is a thicker ring and replaces the front input plate of your t-case so it needs to extend your shaft to make up for the gap (hence the new input shaft), JB's is somewhere in the 7/8"-1" thick range. Most all other clocking rings are steel and are 3/8" thick. Don't let the thicknesses worry you, I have never seen or heard of a standard clocking ring fail. For some reason it looks like JB is over engineering their stuff to make it absolutely 100% bullet proof, but you do have to shell out the cash for it.
Cameron Gunlock
1981 CJ8 -
post #7 of 9 Old 11-30-2011, 11:55 AM
Erik719
1983 CJ7
Not to mention $50 vs. $250.
'80 CJ7 - Gone but not forgotten
'83 CJ7 - Donkey
Erik719 is offline
post #8 of 9 Old 12-01-2011, 05:08 AM Thread Starter
cadesertjp
Thanks everyone,,,,,,,,
Chris
post #9 of 9 Old 12-01-2011, 05:46 AM
nshefbuch
1982 CJ7
I used JB kit and it was great except it doesn't come with new shims for the new output shaft bearing. Keep in mind by clocking the tcase you change your driveshaft angles and may result in needing a cv joint. Also the spacer will change length of the shafts by close to one inch.
CJ7/SOA /5.3LS/t18a/d300 clock/37"Pitbull Rockers/H1's/14 bolt detroit/d44 ARB 4.10 High Steer
nshefbuch is offline
1985 CJ8 swapping in Dodge 1 ton Dana 44 front and Dana 60 rear?????????? JeepScrambler Jeep CJ Forum 8 05-21-2012 06:30 PM
Dana 30 ->ford 9" or Dana 44 Front Axle Swap smoothop Jeep CJ Forum 9 09-18-2011 09:28 AM
Dana 30 Narrow - Dana 30 Wide swap T3hRustyWalnut Jeep CJ Forum 12 04-23-2009 08:26 PM
Switch from T176 and Dana 300 to T150 and Dana 20?? Need Advice CJ5Freak Jeep CJ Forum 11 07-26-2008 06:56 AM
Scout dana 20 vs jeep dana 20 (internal gears) pityocamptes Jeep CJ Forum 3 05-18-2004 11:19 PM
