Dana 30 U-Joints (OEM vs. Spicer) - Page 2 - JeepForum.com
post #16 of 23 Old 10-22-2012, 09:10 PM Thread Starter
diddy2003
Originally Posted by DezertXj88 View Post
Only thing I would add is the full circle clip upgrade The normal set has a c-clip & thats the weak point. With a full circle clip its much stronger & is how all the "alloy" shafts come.
Where do I get those? Thanks
diddy2003 is offline
post #17 of 23 Old 10-22-2012, 09:26 PM
80cj
80cj's Avatar
1980 CJ5
While you have the shafts out, it would be a good time to look at the spindle bearings,
80cj is offline
post #18 of 23 Old 10-22-2012, 09:29 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Take a look at the inner machined area of your axle shaft ears nearest where they start to get thicker and take a turn towards the shaft to see if they will accept the full circle clips.
You can do this by looking at your current c-clip set-up are verify if there's enough machined space so that a full circle clip can be utilized.
Joe Dillard is offline
post #19 of 23 Old 10-22-2012, 09:57 PM
DezertXj88
1990 XJ Cherokee
http://www.jeepforum.com/forum/f140/...pgrade-416890/
DezertXj88 is offline
post #20 of 23 Old 10-23-2012, 07:43 AM
CSP
And again, the CJ uses smaller 5-260x ujoints, so none of the parts in that thread would be applicable in the OPs case.
CSP is offline
post #21 of 23 Old 10-24-2012, 07:00 PM Thread Starter
diddy2003
Thanks, I noticed that too.
Now I just have to find a good spindle rebuild kit for both sides. Any recommendations? I already found these that I should probably change since I am doing the U Joints.
http://www.partsgeek.com/ss/?ssq=set...1984&make=Jeep
post #22 of 23 Old 10-24-2012, 08:06 PM
DezertXj88
1990 XJ Cherokee
Ok I'm a noob for not checking where this was posted:P I just check the new thread link & reply to what I can lol.
post #23 of 23 Old 10-25-2012, 08:28 AM
CSP
You might read all the replies before posting.
CSP is offline
axle , dana 30 , spicer , u-joint , u-joint upgrade
