dana 30 spindle disassembly - JeepForum.com
post #1 of 13 Old 01-14-2010, 10:44 PM Thread Starter
computertech
1974 CJ5
I noticed that my wheel bearings were a little bit loose when I first got my Jeep. So, I decided to finally take a look at them. I jacked up the Jeep, removed the wheel and drum, then proceeded to take off the lock-out hub. I then removed the snap ring and the rest of the hub. Behind this were the wheel bearing retaining nuts. I'm used to just taking off the outer nut, lock washer, and then the second nut. Then you have access to the wheel bearing. However, in front of the two nuts is a steel (locking ring?) that is preventing me from removing the nuts. It has 5 or 6 small holes evenly spaced around it. Does this screw off some kind of way? (I assume it does). If so, where can I find the tool to do so? BTW, this is on a Dana 30 with drum brakes.
1974 Jeep CJ5- 258 I6, 3.73 gears, Dana 20 T-case
1967 Chevrolet Fleetside LWB- 250 I6, 3-on-the-tree, 3.08 gears, A/C
computertech is offline
post #2 of 13 Old 01-14-2010, 11:59 PM
80cj
80cj's Avatar
1980 CJ5
Sounds like you have either Warn Lock-o-matic or automatic hubs as they use the type of nut that you describe. Two of those five holes are for a spanner wrench. The other three holes are for allen head lock screws. Try sticking an allen wrench (I forget what size to use) in some of those holes and see if you can find set screws. The set screws are meant to mate with a lock washer that has corresponding holes.
80cj is offline
post #3 of 13 Old 01-14-2010, 11:59 PM
VACJ7
VACJ7's Avatar
VACJ7 is offline
post #4 of 13 Old 01-15-2010, 05:45 AM
wizim
yes. there are allen bolts in those holes.
99 corvette coupe h/c/i/ and a little nitrous ;) SOLD 77 cj5 4inch skyjacker 33's..SOLD
97 TJ IN THE PROCESS OF MODDING NOW.
04 f-350 psd crew cab 4x4. arp studs,gaskets,edge,mbrp 4inch straight pipe,20's on 35's
08 pontiac G8 GT lowered, longtubes,tune, 20's
wizim is offline
post #5 of 13 Old 01-15-2010, 05:46 AM
wizim
Originally Posted by pwa_fcva View Post
oh hey, thats my jeep
wizim is offline
post #6 of 13 Old 01-15-2010, 11:12 AM Thread Starter
computertech
1974 CJ5
Yep. The sticker on the dash of my Jeep said "Warn Lock-O-Matic hubs" and it says "automatic" on the hub itself. I'll try the allen wrench. Luckily we have a ton of them. If we don't have it, I'm sure my neighbor will. He's a farmer and has a whole drawer devoted to nothing but allen wrenches! Thanks guys. This saved me a lot of cussin' and sore toes. Not to mention sore tires for the Jeep. I'll keep ya'll posted.
post #7 of 13 Old 01-15-2010, 02:26 PM
80cj
80cj's Avatar
1980 CJ5
Just a note regarding removal of those nuts. As I mentioned, two of the holes are designated for a spanner wrench used to tighten/loosen the nut but most people will hit it with a punch and hammer or something similar. Be careful when doing that as I've seen those nuts crack across the holes because of that.
80cj is offline
post #8 of 13 Old 01-15-2010, 10:17 PM Thread Starter
computertech
1974 CJ5
I just tried the hammer and punch today, but as usual they didn't budge. Just like everything else on my Heep. So, I decided to build a removal tool out of some scrap exhaust tubing and welding rods. Well, that didn't go too well. My tool broke. So tomorrow I'm making another one that looks like the spanner wrench that you use on angle grinders for changing the wheels. I'm using nails instead of welding rods. I figured they'll hold up a bit better.
post #9 of 13 Old 01-15-2010, 10:51 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
THe wrenches for these are relatively cheap. Go get one so you don't damage anything. External auto hubs are somewhat of a rarity these days and parts are just about impossible to find. If you don't like them or juast want to swap to a set of prmiums, list them on the binderplant forum. The IH guys love those things and gobble them up. Here is some great info on them.
Lock-O-Matic vs Automatic vs Automatic hubs - Page 5 - Binder Planet Forums
jeepdaddy2000 is online now
post #10 of 13 Old 01-16-2010, 12:20 AM
80cj
80cj's Avatar
1980 CJ5
I have a set of Warn Automatics and they've been relatively trouble free since I installed them in 81. Only real problem I've had with them is I bent the bolts slightly on one side. I guess they must have been a little loose. Got a new set of bolts and torqued them to 30 ft. lbs. and been good ever since.
80cj is offline
post #11 of 13 Old 01-16-2010, 07:05 AM
wizim
wow thats interesting. once i loosened the allens i was able to remove the nut by hand. then again the bearings inside were completly destroyed so there wasnt much tension behind it.
wizim is offline
post #12 of 13 Old 01-16-2010, 08:04 AM
jeepdaddy2000
1971 CJ5
Lock-O-Matic vs Automatic vs Automatic hubs - Binder Planet Forums
Here is the first page. Some good pictures and lots of great info.
post #13 of 13 Old 01-16-2010, 04:36 PM Thread Starter
computertech
1974 CJ5
Great news everyone! I finally got it off. It just took a bigger punch and a lot of hammering. My second tool failed as well. The idea was there, it was just poor materials. Oh well. Looks like I need new bearings and a seal though. I just re-packed the bearings and put it back together until I get all of the parts that I need. At least my wheel doesn't wobble anymore. Thanks everyone for your help. Here's a cold one on me:
Dana 300 disassembly ??? NWA_CJ7 Jeep CJ Forum 14 05-13-2009 09:55 AM
dana 30 spindle removal? petey156 Jeep CJ Forum 15 05-03-2009 03:12 PM
dana 30 spindle brandxj Jeep CJ Forum 1 04-01-2005 11:58 AM
Dana 30 spindle nut size SQF1 Jeep CJ Forum 3 01-08-2005 06:47 PM
Axle Disassembly -- Spindle Problems GroundUpCJ7 Jeep CJ Forum 5 11-30-2001 08:40 PM
