Dana 30 Qustion - JeepForum.com
post #1 of 2 Old 03-30-2009, 11:39 PM Thread Starter
trashmaster2k
Dana 30 Qustion
I have a 76 cj5 and i need a new ring,pinion and carrier. what years of jeep can i use parts from for my jeep?
Thanks
Dave
trashmaster2k is offline
post #2 of 2 Old 03-30-2009, 11:49 PM
Arcticcat843
dakuda is a god
Arcticcat843's Avatar
1980 CJ5
I dont really know the answer to your question but i will tell you this. If you are sticking with a stock ratio (something commonly found) then buy the time you buy the parts and have the gears set you will be better off buying a entire axle and just swapping them out.
even if you buy the parts used you still are going to have to have a master install kit and have to have the gears set....around here you are talking 150 to have them set plus 60 bucks at least for the install kit....
EDIT: i just looked it up for you....Looks like every D30 from 71-83 are the same
http://www.ringpinion.com/DiffDetail...tation%2bFront
Arcticcat843 is offline
1985 CJ8 swapping in Dodge 1 ton Dana 44 front and Dana 60 rear?????????? JeepScrambler Jeep CJ Forum 8 05-21-2012 07:30 PM
Switch from T176 and Dana 300 to T150 and Dana 20?? Need Advice CJ5Freak Jeep CJ Forum 11 07-26-2008 07:56 AM
Wheels anr rims qustion Big John Jeep CJ Forum 3 09-08-2006 03:27 PM
Newbie qustion jeepin_man Jeep CJ Forum 7 08-10-2005 10:03 PM
Scout dana 20 vs jeep dana 20 (internal gears) pityocamptes Jeep CJ Forum 3 05-19-2004 12:19 AM
