Dana 30 Internal Damage. - JeepForum.com
post #1 of 8 Old 05-18-2013, 01:51 PM Thread Starter
Lookinsketchy
When I removed the carrier, I found this damage inside the diff. The PO must have done it. Notwithstanding, I assume because the race sits there it is fine?
Lookinsketchy is offline
post #2 of 8 Old 05-18-2013, 02:01 PM
agear
In my humble opinion I would say that's fine as long as everywhere is flush and flat from the chips.
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #3 of 8 Old 05-18-2013, 02:02 PM Thread Starter
Lookinsketchy
It is flat for sure.
post #4 of 8 Old 05-18-2013, 08:08 PM
CSP
Yep, there's no harm with that. Nothing rotates along that surface so it's not going to cause any more damage.
CSP is offline
post #5 of 8 Old 05-18-2013, 08:33 PM
RenoF250
Are you talking about the scratches in the right side race holder? If so I think it is fine.
RenoF250 is offline
post #6 of 8 Old 05-18-2013, 09:13 PM Thread Starter
Lookinsketchy
The scratches and the chunk of metal missing from the right side race surface.
post #7 of 8 Old 05-18-2013, 10:10 PM
82JeepCJ7
1982 CJ7
I'd run it that way. Since the bearing race sits there and there is nothing rotating on that spot, and its not the drive axle. I've wheeled worse...
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #8 of 8 Old 05-18-2013, 10:31 PM
RenoF250
Yeah, I would run it. That is not where it will fail. Just make sure you got all the debris from that event out.
RenoF250 is offline
